How to get my Monte's acceleration faster
Old Mar 26, 2012 | 09:23 PM
16With01MonteSS's Avatar
Default How to get my Monte's acceleration faster
I forget which gear but its either 2nd or 3rd that accelerates fast as hell and its short. What can i do to make it accelerate faster for other gears..
Old Mar 26, 2012 | 09:35 PM
jimbo7's Avatar
Old Mar 26, 2012 | 09:48 PM
Originally Posted by jimbo7
x2... can't tell if you're joking or trolling but anyways..
there's probably 200 threads on what to do...
Throttle Body
Intake
Ubend Delete
Top-Swap
Turbo..
need I go further?
Old Mar 26, 2012 | 10:04 PM
Budsjlm's Avatar
Throttle Body
Intake
Ubend Delete
Top-Swap
Turbo..
need I go further?
FART CANS!!
Seriously tho go read the link below
https://montecarloforum.com/forum/en...-bumpin-24896/
Old Mar 26, 2012 | 11:08 PM
Mr Grizzly Mint's Avatar
Not doing anything to engine you can go with diff drive ratio on transmission. Cant remember where I saw it but I saw a kit that changes the ratio from 2.93 to 3.26 or 3.93. If it works same as it does on rear axle on a old car going with either of those will increase accel but hurt mpg.
Old Mar 27, 2012 | 12:08 AM
Budsjlm's Avatar
Not a bad suggestion if it was RWD, that would be more exstensive work than minor engine mods, and you would have to get a tune becuase the gearing in the computer would be way off and probably drive like crap,
Plus tearing down a trans isn't somthing amatures should be trying to do
Old Mar 27, 2012 | 11:49 AM
Gotta learn sometime lol. he asked for acceleration not more power. You can increase acceleration without increasing power. on rwd its easy never done it on a fwd tho.
Old Mar 27, 2012 | 07:07 PM
mwjames's Avatar
you can get a bit more throttle response from a new air intake, alot of people talk good about the wizaired cai
Old Mar 27, 2012 | 07:31 PM
Habbibie's Avatar
if you want better acceleration, weight it you're enemy... take out whatever in you're car you don't need/use and that'll help slightly
Old Mar 28, 2012 | 08:22 AM
Intake, Rockers, New Springs, Downpipe, Tune with higher shift points.
DONE.
Also stop launching your car in a "gear", put it in Drive and keep in that way. If you feel the want to "shift" your automatic then you need a tune.
