3800 replacement
Old Nov 6, 2010 | 08:39 PM
johnniep's Avatar
Default 3800 replacement
was looking at another 02 monte ss that need an engine replaced due to intake gasket failure......would a 3800 from a 96 regal bolt up easly
Old Nov 6, 2010 | 08:48 PM
is it series II? shoudl be fine
Old Nov 6, 2010 | 09:03 PM
johnniep's Avatar
not a series 11.....low kms 3800
Old Nov 6, 2010 | 11:43 PM
if its not a series II then there will probably be some modifications needed. you will also probably notice a loss in power, im sure someone will jump in that knows a little bit more on the topic though
Old Nov 7, 2010 | 09:06 PM
augi's Avatar
You may have to re use some sensors, but I don't see why it wouldn't work. If both are obdII, you'll just have to deal with a power loss
Old Nov 7, 2010 | 09:42 PM
mrl390's Avatar
https://montecarloforum.com/forum/sh...861#post273861
Here is a link to an engine for sale in our classified section. Not a bad price for a low mileage Series 2 3800. Should be a direct replacement for your car. I wouldnt waste my time with a series 1 3800. You are losing 30hp. Thats a significant drop in power for the work put into swapping the engine in.
Old Nov 7, 2010 | 09:48 PM
great post Matt, I did see that and it does look like a pretty good price for the money and the miles on it.
Old Nov 7, 2010 | 10:47 PM
Dale3goodwrench's Avatar
Monte Of The Month -- March 2009
And if would like a little more power.
http://cincinnati.craigslist.org/pts/2038733392.html
Old Nov 8, 2010 | 06:45 AM
mrl390's Avatar
/\ /\ /\ Another good low mileage motor. Good price for engine AND transmission.
Old Nov 8, 2010 | 08:14 AM
You're looking to replace the entire engine because of an intake gasket failure? Did the failure really cause that much damage to the entire engine? I would think replacing the gaskets (even if you went down to the heads) would be eaiset....
