3.1L V6 Thermostat Housing Bolt size?
Old Jul 7, 2017 | 01:42 PM
99MonteCarloDan's Avatar
Default 3.1L V6 Thermostat Housing Bolt size?
Does anyone know the bolt size for the 3.1L V6 Thermostat Housing Bolts?
Thanks!
Old Jul 8, 2017 | 10:41 PM
It has been a while, so I don't recall off the top of my head. But knowing GM, I am guessing 10mm or 13mm. You should be able to get a socket or wrench on them to check.
Typically when I change a t-stat on a 3100 or 3400, I remove the throttle body and I get pretty good access to the housing. Some take out the exhaust cross over pipe.
