2003 monte ss rear amp wiring diagram
Old May 18, 2016 | 08:07 AM
Kenny Guido Temprano's Avatar
Default 2003 monte ss rear amp wiring diagram
does anyone have it?
i made a mess of my car. when i tried rewiring the speakers after the radio shop butchered it, i decided to rerun new speaker wires.
but before i did that, i clipped all the wires going to my amp. i then made the mistake of throwing away one of the two plugs that go into my amp. i have the plug with the speaker wires, remote, ground, power.
I need the diagram for the smaller plug next to it on the amp. i bought an after market plug but the colors dont match. i noticed when i had a couple of wires that didnt coincide. thanks!!
Old May 18, 2016 | 09:21 AM
perhaps if someone can take a couple of pictures on thier stock amp set up,i can figure it out from there!!!! thanks.
Old May 18, 2016 | 09:45 AM
Question
Hi `Kenny,
Below are a few links to check out below until one of our Radio tech member's see's your thread & can help you...Good Luck!
Speaker wiring colors - Monte Carlo Forum - Monte Carlo Enthusiast ...
montecarloforum.com › ... › Your Ride › Interior/Audio/Visual Electronics
Dec 23, 2006 - I need to know which ones in the trunk with a factory amp. ... 2003 Monte Carlo SS ... 2006 Chevrolet Monte Carlo Car Radio Wiring Diagrammonte carlo ss 2003 radio wiring diagram (amp) - Monte Carlo ...
Sep 19, 2015
Huge mistakeeee - aftermarket radio / oem harness
Jun 28, 2014
Front and Rear Speaker Wire Colors 02 MC - Monte Carlo Forum ...
Aug 12, 2010
More results from montecarloforum.com
2001-2004 Chevrolet Monte Carlo radio and amp wiring diagram ...
https://answers.yahoo.com/question/?qid=20080427210641AAelHm4
Apr 27, 2008 - 2001-2004 Chevrolet Monte Carlo radio and amp wiring diagram? I need to ... Rear Speakers 6" x 9" Rear Deck ... Right Rear (+) Dark Blue
2003 Monte Carlo remote/switched 12v wire? - The12Volt.com
www.the12volt.com/installbay/forum_posts.asp?tid=71361
Jan 23, 2006 - 9 posts
This is for a 2003 Monte Carlo-. Assuming a stock GM deck and factory rear amp, is there any wire i can tap into from the trunk or under the ...
Chevy monte carlo: can i get a wiring diagram..loom - JustAnswer
www.justanswer.com › Car Questions › Chevy Repair
where can i get a wiring diagram for a chevy monte carlo 2002 radoi plug, .... Remote Radio RightAudio Signal ... Left Rear Speaker Output (+) (UW6/U62) .... Chevrolet Express 3500: 2003 Chevy Express 3500 6L All the 5/12/2016 5/12/2016.
2003 Chevrolet Monte carlo Stereo Installation Kits, harness, wires ...
www.installer.com/cars/by_car.php?carid=1199
Wholesale Car Stereo Kits for 03 CHEVROLET MONTE CARLO - Radio, Harnesses, ... harness plugs into the vehicle's wiring and provides a stereo RCA audio ...
Old May 18, 2016 | 10:18 AM
thank you but sadly, all of the above deal with the "stereo" part of the amp. I need the plug specs for the other parts of the amp.
Old May 18, 2016 | 11:53 AM
Sorry `Kenny that none of the links helped
I don't know about your area of the country, but in my area most of the stereo install shops are pretty friendly & helpful when a customer has a problem. I would stop in to the ones in your area & tell them your situation. Hopefully, you will find a helpful one. Every happy customer will come back & also send their friends...
I do hope a member can help, but stereo hook up & plugs are no my forte...GOOD LUCK on getting your tune's back
Old May 18, 2016 | 01:43 PM
user 35764368's Avatar
I can get you sum pix if yu think an 02 would be the same. just bear with me till shortly after 4pm est
Old May 18, 2016 | 05:10 PM
The plug on the left, which is missing, is the one i need the wiring for.
yes, sharpeezss. i think 2000-3 works!
Old May 18, 2016 | 06:38 PM
ok left to right top 1st
green black tan tan dk green blue with wht stripe
bottom
gr with blk stripe lt blue with black strip white red yellow purple
Old May 18, 2016 | 07:07 PM
shawn parker's Avatar
bottom
I was about to go snap a pic, but thought I should see if someone already did, your post was better than a pic
Old May 20, 2016 | 09:59 AM
THANK YOU! But.....a couple of questions....
which way is the plug pattern? meaning was it with the amp upside down (like in pic) or rightside up?
