2003 3.4 L, oil filler cap question
Old Jul 22, 2015 | 12:28 PM
el pachuco's Avatar
Default 2003 3.4 L, oil filler cap question
Is the cap supposed to be vented?
When I remove the cap while the engine is running, the idle speed drops a bit and there is an obvious tight vacuum seal to break to remove the cap.
Old Jul 22, 2015 | 01:58 PM
TorqueEffect's Avatar
No, lots of engines idle will change when you remove the oil cap. You are basically causing a pressure difference in the crankcase pressure when you remove the cap, which screws with the PCV system, so the air volume going into the intake changes so the idle changes.
I don't think I have ever heard of a vented oil cap personally. Maybe long before they had PCV valves, lol.
Monroe
34
Sep 5, 2016 04:53 AM
daves92camaro
Nov 9, 2012 04:08 AM
The_Maniac
Aug 4, 2012 02:04 AM
RocknSS04
Jan 13, 2008 06:22 PM
