2002 Monte Carlo LS good performance Upgrades
Old Jan 11, 2017 | 10:33 AM
Schaefer's Avatar
Post 2002 Monte Carlo LS good performance Upgrades
Hello im new to these forums, and i was wondering i have a completely stock 2002 Monte Carlo LS i know the 3800 have alot more performance upgrades made for it and turbo/Supercharger kits made for them but i personally do not want to spend that much money since i am a senior in high school. I have a little knowledge on performance upgrades but i was wondering what are some of the better upgrades to do to a 3400, and brands that would be good anything to improve it that wont cost a arm and a leg?
Old Jan 11, 2017 | 11:11 AM
Hello and Welcome to the MCF. Yep being in High School one is usually on a budget. That's all good, use the search bar and you will find numerous articles with regards to your inquiry. Here is one example you can read through. Have a Super day!!
https://montecarloforum.com/forum/fw...p-power-46071/
Old Jan 17, 2017 | 09:36 PM
Welcome!
It is true in the Montes (and other W-bodies) the 3400 is not as popular for mods, but it has them. My ex-wife had an '05 Impala with a 3400 I did a couple of mods too and I also daily drive a '04 Grand Am with the 3400.
Greg provided a good link on 3400 mods. There are a bunch of "cheap" mods you can do. I would recommend L67 coils and a resonator delete as a couple of your first ones. But read the thread, plenty of info to help
Old Jan 18, 2017 | 11:02 AM
Schaefer's Avatar
I think i might have a injector leak so i am going to replace all my injectors what size injector or what type of fuel injectors should i go for my monte carlo
Old Jan 18, 2017 | 10:16 PM
First, replacing all the injectors can be costly and time consuming (as on the 3400, they are under the upper intake). What makes you believe there is a leak? It might be something else or maybe a failed/incorrectly seated o-ring. I would pin-point the issue and if it is a bad injector, replace just the one bad injector.
Old Jan 19, 2017 | 08:47 AM
nitehawkjcb's Avatar
If you do end up replacing injectors, just stay stock... You won't see any gains without boost.
