160* t-stat
Old Aug 30, 2008 | 11:38 AM
v8_Killa's Avatar
Default 160* t-stat
hay guys i wanted to know if any one ever replaced there tstat for a cloder on and knew step by step how to do it and what i should expect to gain from it? thank you and the car is already open cooling down right now
Old Aug 30, 2008 | 11:50 AM
2000_BLACK_SS's Avatar
Default RE: 160* t-stat
160t-stat is entirly to cold for your setup right now, and often there are alot of people that say that the t-stats dont even do anything.
i would say just get a 180 tstat and you will be fine, I put a 180 in my car and it does run cooler than it did before but thats the only difference i can tell because the gauge says that it is running cooler.
Old Aug 30, 2008 | 12:04 PM
kweef's Avatar
yep g with a 180...a 160 will prolly throw a code
first step in changin ur tstat is gettin a new tstat and the gasket
next make sure the engine is cold when u go to change it...
next find the tstat housing(follow radiator hose to the top and there will b a housing with 2 bolts)
remove the top of the housing and take the old tstat out and remove the old gasket...make sure nothing gets into the housing
put in the new gasket and tstat and then bleed out the air in the line
Old Aug 30, 2008 | 12:38 PM
v8_Killa's Avatar
how do i bleed it?
Old Aug 30, 2008 | 12:52 PM
kweef's Avatar
there are vents on the system... i dont remember where they are at the moment so next time i make it to the car ill have to check
Old Aug 30, 2008 | 01:03 PM
v8_Killa's Avatar
ok i'll wait i dont want to mess it up are there any tools i will need to bleed it?
Old Aug 30, 2008 | 01:13 PM
kweef's Avatar
shouldnt b anything special...ill go take a look now
Old Aug 30, 2008 | 01:20 PM
kweef's Avatar
there is a vent located right on top of the housing
looks like a small metric wrench
Old Aug 30, 2008 | 01:29 PM
the way i bleed out the air on my car is buy just taking the radiator cap off and start the car and let it run for about 2-3mins and then all the air is usually out of mine. ( i did this when i put in my P&P LIM and never had a problem with it)
Old Aug 31, 2008 | 10:04 AM
v8_Killa's Avatar
ok so i got the 180 (which cost more) new gaskit, and a new hose that i plan on painting red to match my other parts, and the tools todo the swap,now and i'm waiting for the car to cool off wish me luck
