7th Gen ('06-'07): 07 Monte Carlo transmission whine when idling and ps leak
It doesn't whine all the time only on a cold start and as soon as you start driving it goes away, it doesn't shift funky, or slip at all, just wondering if there's something I can keep my eyes on or if these cars just like to do it, and now the power steering leak is pretty bad and is leaking on the serpentine belt so I was just wondering if there is any common leaks on these cars.my first post on this forum so any comments/suggestions would be greatly appreciated
My guess is this is not a transmission whine and is actually a whine from the power steering pump due to low fluid. I would suggest fixing that leak and not driving the car if it is spraying fluid on the belt.
As for common leaks, I am not sure on the engine options in the 2007. But at this age, you will have hoses that are dry rotting and leaking if they have not been serviced.
6th Gen ('00-'05): Really bad steering fluid leak 😬
Abrahaml1
Nov 19, 2018 09:16 AM
6th Gen ('00-'05): Power steering leak
Judy Janczura Evans
Aug 17, 2018 05:50 PM
