Leaking transmission fluid
Old Dec 22, 2021 | 10:14 PM
AL89ER's Avatar
Default Leaking transmission fluid
Has Anybody ever used bluedevil transmission stop leak
Old Dec 23, 2021 | 08:09 PM
Jeffs02rwdSS's Avatar
Personally I would never use a chemical to try to stop a leak. Most leaks are pretty easy to solve and only requires a gasket or seal, usually less than $30 and a few hours of time.
Old Dec 24, 2021 | 07:47 AM
I also would personally never use any "stop leak" type of treatment. That being said, the scrap yard I frequent also does a little work on my cars when I dont have time and they threw some stop leak in my Firebird's transmission about a month ago. The plan was to replace the trans soon after so he thought, "why not" I guess. It was a "stop slip/stop leak" something or another. The stuff worked so well that ive put off the trans replacement until I get a failure. I had a horribly hard 1st-2nd shift and a leak that was dumping about a quart a week into my driveway both of which this stuff "fixed".
All that being said now, I still would never choose to use it but theres proof it can work.
stillonly1
Sep 6, 2013 10:09 PM
bigmichaelcool
Dec 30, 2011 03:56 PM
bikerboyzzky
Mar 20, 2011 09:24 AM
Jack The Ripper
Mar 31, 2010 01:46 AM
tj4ndirish
Jul 30, 2009 08:50 PM
