****IN **** I NEED HELP!!!
Old Oct 16, 2007 | 03:28 PM
Chevy_Sean's Avatar
Default ****IN **** I NEED HELP!!!
My Monte won't turn on. What should I do?
Old Oct 16, 2007 | 03:31 PM
06MCLTZ's Avatar
Default RE: ****IN **** I NEED HELP!!!
Is it turning over or anything? Making a clicking noise or anything?
Old Oct 16, 2007 | 05:43 PM
GrandPaDave's Avatar
You actually have a car where you can jump the solenoid to the starter armature with a screwdriver.
If nothing happens or it just clicks, follow the hot cable back to the battery and check the connections.
If the battery is good and the connectons are good, you might have a bad starter or solenoid.
If the car turns but doesn't start with the key in the on position, you have issues with your ignition and/or ignition switch.
If the car turns over with the screwdriver method, you have a bad connectionto the starter.
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
zk6216
Mar 11, 2008 11:19 PM
mickey
Aug 23, 2006 05:31 PM
