Repair Guide: Ignition Cylinder Replace (Passlock fix)
Old 02-22-2008, 12:06 PM
psson24's Avatar
Default Ignition Cylinder Replace (Passlock fix)
Finally Completed
Tools you will need
-10mm socket
-Medium extention
-7mm Nut drive
-1 or 2 Flat bladed screw drivers
-Pull off the Lower panel from the driver side 9remove the small light bulb)
-Pull off the Driver side fuse panel
-Remove the two 7mm bolts holding on the mid panel (under the steering wheel)
-This panel pulls straight out towards the driverseat (disconnect the remote trunk switch)
-Remove the four 7mm bolts from the front of the sheet medal panel (three on left side on on right side)
-Looking from under the steering column you will see four 10mm bold hold in the sheet medal plate in place. Remove all of these
-open your glove box and look to the left for the one 7mm bolt holding on the main bash panel. remove this
-look at the driver side fuse box and you will see one 7mm bolt holding the main dash as well. remove this
-Lower your steering wheel to it's lwest position
-set the parking break, turn the key to ON, shift out of part to 1
-Simply pull the main bash piece off ( I started from the passenger side) remember that your hazard switch is still connected
-Shift back to park
-Look up under the bash, you can see the Ingition cyclinder
-Look for the cable going into the lower portion of the module
-with the key in ON, push the tab and remove this cable
-Remove the 10 mm bolts on the front to release the ignition module.
-Return to OFF and work the module out from behind the dash to the floorboard.
-with the key in ON again roll the module until you see a small tab, push and the ignition cylinder will slide right out
Once you new one is in you do the relearn as follows
-Attempt to start
-Leave in key in ON for ~10 min SECURITY will stop flahing and go off
-Turn key ot OFF wait 5 seconds
-Attempt to start
-Attempt to start
-Attempt to start and it should as well as it will relearn your new passlock
hope this helps as well as saves other time and money
If anyone needs pictures let me know I have some that I took as I replaced eveything
-Rick
Old 02-22-2008, 12:13 PM
Default RE: Ignition Cylinder Replace (Passlock fix)
Hi `Rick
Great write `up. Thanks for
posting sharing.
How's the weather in Hawaii ?
What is the cost of `gas ?
Do you see many Monte Carlo's there ?
Wish U a `Happy,
`Space
Old 02-22-2008, 12:27 PM
psson24's Avatar
Weather is great mid 60's to high 80's daily
Gas is ~3.50 for 92
Not a whole lot od montes out here but they are here. Lots of foreign cars
Old 02-22-2008, 12:49 PM
Hi `Rick,
Thanks for your response.
I think we are all going to see higher`gas prices
Hope you post some pic's of your Monte Carlo in Hawaii.
Would love to see them.
Are you in the military? Do you like living there ?
Do you Surf? I dream of visiting there
Thanks, `Space
WoW....Oh WoW
"To Dare 2 `Dream"
Last edited by Taz; 01-24-2010 at 09:21 PM. Reason: Repaired formatting errors from old forum
Old 03-24-2011, 08:10 AM
Default Psson24 i need pictures please
The Ingition in my 2002 Monte Carlo is hard to turn, You have to move the steering wheel back and forth to get it to work, Will the procedure you gave fix my problem?
Can you send pictures please to keelklan@***.net
Duane
Old 06-07-2011, 10:17 PM
So i am thinking that i need a new ignition cyl. twice in the past 10 to 12 months my 2002 ss will have a no crank no start. I will try jumping it and tapping the starter but nothing will happen. then out of no where i will turn the key and it will start right up. oh and once in a while the security light will come on while driving.
So what do you think. replace the ignition or just try to relearn it?
thanks for any help.
Old 08-25-2011, 08:13 AM
Originally Posted by psson24
Finally Completed
Tools you will need
-10mm socket
-Medium extention
-7mm Nut drive
-Shift back to park
-Attempt to start
-Attempt to start
-Attempt to start
-Rick
@ PSSON24
Could you please send me pics of the ignition cylinder change? I'm thinking it might fix my problem - my security system randomly goes off (lights/horn going off)
Old 08-25-2011, 08:34 AM
Good luck man, this thread is more than 3 years old...
Old 08-25-2011, 08:50 AM
Thought I would try..
Old 09-22-2011, 08:05 PM
Samehere because I do need the photos as well. Even though the instructions are well written, I already know how to relearn the system... I do all GM cars at work! Now installing that, thats another story...lol
Quick Reply: Repair Guide: Ignition Cylinder Replace (Passlock fix)
