Mod Guide: How to Install SS GFX High Sport Trim OEM Ground Effects
I didn't have a template. I used white rope. Also can use a rope/heavy twin/spare electrical wire).
- Lay rope down on top of GFX edge above tabs
- mark rope with a marker for the width of the each tab
- be sure to also mark the center/nose on the rope
- once rope is completely marked..... tape the rope to your car's bumper (per your center mark) just below the feature line where you will be drilling the holes. Transfer the tab marks from the rope to the car bumper by marking in the feature line.
- remove rope and drill away per the picture instructions I posted earlier in this thread
How many of the metal plates are needed between front & rear. I'm having my shop redo mine since they remounted my rear affect without them after I was rear ended & t
when they cut out for the tab ps rear bumper they cut too low so you see the slot the tab goes into
Do you / can you share a copy of templates ???? I'll pay for them.
My body shop obvious needs them before they ruin bumper # 2
Thank you!!!!
Thank you!!!!
How many of the metal plates are needed . I'm having my shop redo mine since they remounted my rear affect without them after I was rear ended & to boot
when they cut out for the tab ps rear bumper they cut too low so you see the slot the tab goes into.you did an awesome job!!!
I emailed this link to my Bodyshop so they don't jack up again.
Thank you!!!!
Thank you!!!!
chevymontess
40
Jul 3, 2015 03:58 PM
