Repair Guide: How to change light bulbs in mirror
Old Apr 9, 2013 | 08:38 PM
sdowney's Avatar
Default How to change light bulbs in mirror
Changing the light bulb in the mirror is a slight pain but I figured out an easy way to do it.
1. Take of the clear plastic cover using a small flat head screw driver.
2. Use a rubber grip (found on clicky pens and mechanical pencils) to wrap around the light bulb.
3. Grab the rubber as close to the bulb as possible and wiggle it out.
4. It may take a few trys but it works pretty well.
I discovered this because I wanted to put LED's in place of the stock bulbs. It's much brighter and looks pretty cool too!
Pictures attached.
Leave questions in a reply
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 22, 2013 | 07:20 PM
owens91's Avatar
wish you would of took a pic of the bulb
Old Apr 22, 2013 | 09:28 PM
sdowney's Avatar
Sorry. I didnt even think about it, because it looks just like any other light bulb.
Old Apr 23, 2013 | 07:13 AM
03SSLE's Avatar
Pictures attached.
I use this same method, but with a piece of rubber hose instead of a grip off a pen. Works great!
Old Apr 23, 2013 | 04:05 PM
owens91's Avatar
was i did was use pliers and tape, tape around the bulb then wiggle lose, but the led looks like the normal bulb? i didnt know that good
Old Apr 23, 2013 | 06:37 PM
sdowney's Avatar
Yes. The LED bulb goes in very easily. I was able to just slide it in with my hands. Just be sure that its the correct size. I believe its a 194. You might want to double check before you buy bulbs
Old Apr 23, 2013 | 06:38 PM
sdowney's Avatar
I bet! I felt like a genius when I thought of this. LOL
Old Apr 24, 2013 | 11:48 AM
owens91's Avatar
yup, i went on superbrightleds.com and that have basically a bulb finder, i just wasnt sure on how the new ones looked like. but now i play the waiting game
Old Apr 24, 2013 | 12:18 PM
03SSLE's Avatar
Originally Posted by owens91
...now i play the waiting game
That's always the worst part!
I put this style of bulbs in my mirror map lights and they work great!
2 x T10 168 194 W5W Xenon White 12 3020 SMD LED Car Turn Wedge Light Lamp Bulb | eBay
Old Apr 24, 2013 | 08:40 PM
owens91's Avatar
i seen those i just wasnt sure if it would fit in the bulb socket
