Repair Guide: headlight issue resolution
Old Dec 14, 2014 | 03:57 PM
Budsjlm's Avatar
Default headlight issue resolution
This should be the same 01-05
Had kind of a weird issue with my 01 after swapping from hid back to regular bulbs when one of my hid bulbs burnt out.
The issue :
Driver side headlight was dim and the high beam was on aswell but aswell very dim. The oassanger side headlight was on no differance in light output but the high beam was on very dimly.
Started with cleaning the ground that had no change,
Turns out it was a fuse so it is an easy fix
Driver side:
Passanger side:
The fuse spot:
It was a 15a fuse in the DRL/EXT LT Sit in the under hood fuse box,
Replaced the fuseand now I have proper working lights again.. hope this helps
Old Dec 15, 2014 | 09:08 AM
Justin:
Great Find and thanks for the fix!
Old Dec 15, 2014 | 07:39 PM
As always, thanks Justin for good write up. I've moved this into our Tech Guides section.
Zod642
41
Jan 27, 2018 09:56 PM
TAV
Apr 20, 2012 08:18 AM
Cowboy6622
Jan 6, 2011 01:26 PM
nemesis
Dec 28, 2009 09:29 PM
ramos87ss
Jun 5, 2009 08:25 AM
