Repair Guide: Finally!!! Gauge Cluster Problem Fix!! - Stepper Motor
Old Dec 21, 2011 | 05:12 AM
  #71
Paul Horst's Avatar
Originally Posted by oh3monteSS
Should I just pay the Dealership to do this? All 4 of my Left Side Gauges don't work
The dealership won't repair your ipc, they will get a new one. Cost $600-$700.
I did mine for less than $50, and included pencil soldering iron. I would think that if you could change oil, you could do this. Previous posts have instructions. If you don't want to do it yourself, bb engineering does a great job, for very reasonable $. They can be found in the previous posts on this thread.
Old Jan 10, 2012 | 01:28 PM
  #72
oh3monteSS's Avatar
Getting Ready to Head outside to see if I can take mine out... Wish me luck!!!
Old Jan 11, 2012 | 06:41 PM
  #73
ltman's Avatar
i replaced my stepper motors when all my gauges went haywire. Very easy. I reset my pointers a little different. I left the pointers off and plugged the cluster back into the wiring harness, started the car and shut it off after10 seconds. This set all the stepper motors at zero. brought cluster back inside and mounted all pointers at zero. Worked great. Good time to replace any burnt out cluster lights at this time since they are also soldered in. Was able to replace the burnt out bulb in my heat temp selector. It can be done.
Old Jan 11, 2012 | 07:37 PM
  #74
forgotten's Avatar
My wifes trailblazer has the same faulty stepper motors. I replaced them and the leds at the same time. Only thing with the trailblazer gauge cluster is the face is bluer and the lights are yellower to get the white color that shines threw. Is it the same color with the monte carlos?
Old Jan 14, 2012 | 03:23 PM
  #75
jasonsmith's Avatar
Since it would be a good idea to change the bulbs. What is the part number for the soldered in bulbs in the cluster?
Old Jan 15, 2012 | 07:48 AM
  #76
Sir Monte's Avatar
Radio Shack #272-1154 and they are $2.19 each.
Old Jan 17, 2012 | 04:46 AM
  #77
jasonsmith's Avatar
What about the bulbs for the HVAC? Those have blue covers on some of the bulbs that are too big for the radio shack bulbs.
Old Jan 18, 2012 | 02:07 AM
  #78
Larrysmonte's Avatar
Old Feb 2, 2012 | 12:30 PM
  #79
04chevyboy's Avatar
Originally Posted by Larrysmonte
I was going to use them as they are the best deal with light included but figured I might as well do it myself soo if I ever come across this problem again:p
Old Feb 5, 2012 | 11:19 PM
  #80
04chevyboy's Avatar
I purchessed my motors,and is there a certain wire i should use to solder them back on with,or will any work? thanks!
