Repair Guide: Changing Brakes and Rotors
Old Feb 14, 2012 | 09:18 AM
asmart82's Avatar
I did my front brakes yesterday. I forgot to remove the cap for my fluid reservoir and while compressing the piston, I heard a pop and fluid started draining from between the master cylinder and power booster. Any ideas what I might have gotten myself into here? When I press/depress the brake pedal now, I can hear air compression from the power booster and it moves in and out with the compression of the brake pedal.
Old Jul 12, 2012 | 12:30 PM
nascar43's Avatar
Default brakes and rotors
Great write up and photos. I'm looking at doing this for mine. Who did you order your parts from ?
Old Sep 19, 2012 | 10:16 PM
WoodstockCarlo's Avatar
Is this something a beginner should attempt? My rear brakes are screeching everytime I hit my brakes and I really dont want to pay my local repair shop over $250 just to change it for me. I can change a flat tire but I've never attempted this before. Should I try it?
Old Sep 19, 2012 | 10:22 PM
Mr Grizzly Mint's Avatar
Calipers are easy its the old drums that are a pain with springs and crap.
Old Sep 20, 2012 | 07:01 AM
03SSLE's Avatar
Replacing the rotors and pads is a fairly simple job that even a person with minimal mechanical aptitude should be able to accomplish. Doing a search at YouTube should bring up a few examples, but if you plan on doing your own vehicle maintenance it would probably be beneficial to invest in a repair manual.
Old Sep 20, 2012 | 07:26 AM
I agree with Mike. It is a fairly simple job that can be accomplished with some simple hand tools. There are tons of videos on youtube, I would watch more then one to make sure you have all the info you need. Also I would suggest only taking apart one side at a time so if you get stuck on reassembly you can look at the other side and match it up. If your not replacing the rotors you should at least have them turned, most brake shops will do this for a small fee. Some cars its cheaper to just buy new rotors.
Old Sep 20, 2012 | 08:07 AM
I would recommend getting a good socket set for this. Those caliper/bracket bolts can be on there PRETTY TIGHT.
Old Dec 26, 2013 | 11:03 PM
03_MONTE SS's Avatar
Default brake upgrade questions too
Hello everyone,
I am in need of brakes to. I have been looking and have found a rear upgrade kit on zzp here ZZPerformance - 12" Rear Brake Upgrade kit #ZZ-12BRK-REAR
Has anyone put these on? Also if i go with hawk pads and the fbody kit here is the stainless brake lines really needed? ZZPerformance - F-Body Dual Aluminum Piston Brake Kit #ZZ-FBDY-BRKT
Also when upgrading brakes what about e-brakes on the rear, and do we need to flush brake fluid completely? Any info would be appreciated thanks
Luke, 2003 MONTE SS ; HS Package
Old Dec 27, 2013 | 12:18 AM
l67ss's Avatar
I would upgrade the front brakes first, thats where you need the most stopping power. Ive heard that gxp drilled and slotted 13" rotors/calipers are fairly easy to swap onto 00-05 montes
Originally Posted by 03_MONTE SS
Hello everyone,
Norris15
Mar 10, 2011 06:51 PM
heavy chevy
Sep 4, 2009 10:06 PM
iMSeRiOuS
Jul 5, 2009 08:20 PM
csmith045
Dec 13, 2008 07:27 PM
rickyk55
Aug 18, 2008 09:11 PM
