Mod Guide: Big 3 upgrade
Old Dec 16, 2009 | 01:25 PM
Montecarloguy07's Avatar
When doing the big three upgrade do you have to run a fuse on the wire you are running from the alt to the batt....some sites i seen it and others they didnt put one on....and if you do have to put a fuse in between what size should the fuse be...to match the wire gauge or to match the amps on the alt...thanks
Old Dec 16, 2009 | 04:13 PM
Dbl_D718's Avatar
Your fuse should either match the capacity of your wire or the be slightly larger than your alternator's output, whichever is lower (but it wouldn't make sense to have a wire that couldn't handle the altnerator's output lol). It's a good idea to have one as it's protecting both the battery and the alternator.
Old Dec 17, 2009 | 12:04 AM
04MonteLS's Avatar
Anytime you use an inline fuse MAKE SURE TO USE A FUSE RATED JUST BELOW THE MAX CURRENT CAPACITY OF THE WIRE IT'S CONNECTED TO. It's not necessary to fuse it, but it wouldn't hurt if you did.
Old Jan 15, 2010 | 12:11 PM
04TurboSS's Avatar
Awaiting Email Confirmation
Im going to be doing the big 3 this weekend. Does anyone know where the chassis/engine block ground is orginally located?
Old Sep 22, 2010 | 10:42 PM
04MonteLS's Avatar
I couldn't locate it, didn't really try all that hard either but I did look around a good bit. If I were you, I wouldn't remove it though even if you do find it. Just find another spot to add in the new wire and call it a day
Old Sep 23, 2010 | 04:15 PM
M.C.BOB's Avatar
On my 01 the ground is towards the front of the car and is very very difficult to get to/loosen, which brings me to my question, where is a good place to ground it to on the block? Could someone post a picture. I manged to upgrade the fuse to the chassis which is about 6 inches long of wire, was very easy, but I've yet to sand it to bare metal.
I couldn't manage to change out the stock power wire so I added a new lead straight from the battery to the alt. I also couldn't change the power from the battery to the aux posts. The bolt simply won't loosen up which is very frustrating. Maybe it's just me but IMO GM did a terrible job on their electrical system lol
Also I'm reading 13.8X volts and I'm not sure why. At first I just managed to change the ground to the chassis, had a reading around 14.5X volts, added the extra lead from the alt to the batt, got a reading around 13.5X. Took it off, no change. I'm not sure what's going on but it's very frustrating. Sorry for the long post
Edit: Thinking about the voltage problem, when I got the 14.XX reading it was a cold start therefore the rpms were higher which may have caused the better/higher reading. The other times the car was already warmed up and the rpms were lower. Do you think my idle speed is too low?
Old Sep 23, 2010 | 06:54 PM
jaws2008's Avatar
GOT SPL
The Alternator doesnt fully kick in till about 1500RPMs thats why it reads higher than.
Old Apr 14, 2013 | 06:40 AM
Lorenzo's Avatar
Could someone help me with this? I have to do it but im confused on how I should do it. The pictures that bigriggs posted helps alot, but dbl said that the chassis to ground is wrong? Does anyone have pictures in how they grounded the engine properly, also is the negative battery terminal to that classic ground right then? And what size fuse should you use for 0 gauge wiring ?
LTs_Carlo_SS
Apr 20, 2011 03:43 PM
Randdady
Mar 5, 2011 09:07 AM
04MonteLS
14
Nov 27, 2010 07:57 PM
Pure2sin
34
Sep 30, 2010 01:09 AM
bumpin96monte
Oct 15, 2009 04:25 PM
