Repair Guide: 3800 Starter Replacemnet How To (With pics)
Old Jun 18, 2012 | 10:46 AM
Budsjlm's Avatar
Default 3800 Starter Replacemnet How To (With pics)
This should be a general guide to 5th and 6th Gen 3800 starter replacement
Yours may be slightly different this was done on my 2001 MC SS Pace Car
Mine went out this weekend and thought i'd do a write up while i was replacing it. doing this, taking pics ect took me just under 45 min
Any beginer should be able to do this in about an hr,
Depending on skill level i would say this could take anywhere from 30 min to and hour start to finish
Tools needed:
Jack,
Jack stands.
or a set of wheel ramps,
3/8in Ratchet
various exstentions
8mm Socket
10mm Socket
12mm Socket
13mm Socket
15mm Socket
Step1: Jack Up your car and Put onto Jack stands or drive onto wheel ramps
Step2: Grab you 8mm and disconect battery
(i'm weird and unhook both pos and neg that way no way of having isssues)
(i actually used a 1/4in ratchet with a 8mm)
Step3: grab your 10mm and Pull off air Deflector and se it aside
(5 bolts)
Step4: Grab your 10mm again and pull off plastic flywheel inspection cover
(3 bolts 2 on the botom one towards the front)
This is the one that faces the front, i used the space between the radiator and subframe to pull it out with a deepwall 10mm and extention
Step 6: Grab your 15mm and extention to unbolt starter
(2bolts)(i like to use a swivel extention on the front bolt that way the socket makes better contact with the bolt as the subfram is just a hair in the way)
i did not get a pic of this but i put stars over there the bots are in a pic
Step6: now that the starter is loose i like to tip it to be able to get to the conections small one was 8mm and big one was 13mm on the old 12mm on the new
Step7: pull it out and compair to new part, you never know parts stores can mess up too! i always like to comapair the old to new and inspect the new part befor putting it in,
To install you just follow these instructions in revere order
in the end you should have your new starter in and ready to go@
I hope this is Informative enough and helps out keeping past,presant and future members on the road while saving them Money
Old Jun 18, 2012 | 10:47 AM
How-to Approved!
Thanks Justin
Old Jun 18, 2012 | 10:42 PM
Enzo354's Avatar
STILL SLOW
I have never even seen my starter yet, this thread should come in very handy sometime.
Old Jun 18, 2012 | 10:46 PM
BlackRainSS's Avatar
How-to Approved!
Thanks Justin
100% ageed great how to. Thankfully my starters just fine. I'll have to keep this in mind when the time comes though.
Old Nov 23, 2012 | 07:31 AM
Thanks Justin!
Clear and consise Post!
You made it look easy!
Old Nov 23, 2012 | 10:58 AM
DE02Carlo's Avatar
Thanks for the "how to" it should save some time for people...
Old Oct 9, 2016 | 05:17 PM
Storman1's Avatar
Budjlm you are the man, awesome how to !!!!!
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
rmorman
Oct 24, 2013 06:32 PM
golfstud2k4
Sep 29, 2010 03:37 PM
akboxboy
Aug 15, 2008 08:26 AM
