wow... why me. help?
Old Aug 27, 2007 | 11:01 AM
vita's Avatar
Default wow... why me. help?
hey guys... i was driving back on he highway today when all of a sudden, my montes cruise control lost speed... dropped about 5 miles an hour, but the cruise was still engaged. so, i pressed the break to take it off and try to figure out what just happened, and the car seems to be coasting fine, no service lights, no nothing, so i press the gas. it speeds up about 1 mile an hour a second. so i floor it, to see if it would go any faster. no luck. im a little afriad now, so I let off of the gas, turn off my jetchip and try it again, but this time it goes normal. Im thinking, ok, my jetchip is acting up, but sure enough, no, its doing it with it off too. it has a few times where nothing will be "up to speed" and my rpms litterally wont rise above 2/2.5k. I got home, turned the car off, turned it back on with the jetchip on, and it revs into the 4k off the start. I hold the break and it idles normal. any idea what is wrong? I just disconected the battery to maybe reset a few sensors and give it a fresh start... well see how that works?
Old Aug 27, 2007 | 11:16 AM
Default RE: wow... why me. help?
WoW.......Why me ?
[sm=badbadbad.gif] Because you have been `Bad
[sm=groupwave.gif]
[sm=grinangel.gif]
Hi `Mike, sorry 2 read about your prob : (
I hope a member can help It could just be that your cruise
unit is bad : ( I will search more for theanswer.
Good Luck, `Space
Old Aug 27, 2007 | 11:25 AM
[align=center]Mike, my grandfather said that it could be a[/align][align=center]bad speed sensor, and also to clean the throttle body[/align][align=center]or Replace the cruise control module.[/align][align=center](Something else to check)[/align][align=center][:-][/align]
Mike, I don't know `if you Monte has
a switch on the brake pedal, but this may have become
out of adjustment that could be causing your problem.
[align=center]
[/align][align=center][/align][align=center]I'll keep checking. Good Luck![/align][align=center][/align][align=center][/align]
[/align]
Old Aug 27, 2007 | 11:35 AM
vita's Avatar
thanks, I appreciate the info... right now Im just trying to figure out how I'm gettting to work in a few hours...[&:]
Old Aug 27, 2007 | 11:48 AM
ORIGINAL: vita
We sure find out whoour friends are when things are Bad.
"U got 2 have Friends"
or
Old Aug 27, 2007 | 01:20 PM
vita's Avatar
lol, well, hitch hiking by me... not such a great idea. we have some crazy people up here in my part of Wisconsin. I reconnected the battery and it seems to be working normal again, Im going to take it back out to the highway again when I got to work (or maybe when I come home... ) and see if it does it again. I have NO idea what it could be though....
Budsjlm
Apr 12, 2012 08:20 AM
Jun 23, 2011 12:20 PM
Budsjlm
Feb 15, 2011 12:21 PM
augi
Feb 13, 2011 08:15 PM
God_Bot
Oct 19, 2008 07:31 PM
