which would be better???
Old Aug 21, 2011 | 09:28 PM
bama_z34's Avatar
yeah if i keep the monte thats what im gonna do, mine only has 106xxx miles but it drives like it has 300k.
Old Aug 21, 2011 | 09:30 PM
z34phoenix's Avatar
yeah it does. the exhaust manifolds on the pre 96 and 96+ look pretty much the same from at first glance... the major diff is that we have oval exhaust ports... the older ones are D shaped. for some reason they changed the bolt pattern on the rear heads in 96+ before a front manifold could be put on the rear and the opening would be on the correct side to allow to make a custom Xover... now we can not do this.
more reason to consider a 95 or older block if i do a turbo setup is in addition to the exhaust benefit, is that instead of our 9.7:1 compression they have a 9.5:1 compression which would help a bit when doing boost. i would still use the 96 cams and intake setup though.
Old Aug 21, 2011 | 09:31 PM
bama_z34's Avatar
i kinda wish that my grandmother would have picked the 97 gtp instead. the only reason she picked the monte was bc it was white and the gtp was black. but hey i guess if she did that i would have never found the mcf :/
Old Aug 22, 2011 | 12:17 AM
Enzo354's Avatar
STILL SLOW
If you want to swap in a l36 and then upgrade it why not just get an l67. Pretty much the same price and more ho then you can get the l36 to unless you boost it. Or spend a lot on it. Honestly a n/a 3800 gets walked by most traffic these days anyway.
Old Aug 22, 2011 | 12:37 AM
bama_z34's Avatar
l36 has more compression and can be top swapped or turboed down the road. plus its easier to get an l36 down here than to get an l67
Old Aug 22, 2011 | 03:33 PM
z34phoenix's Avatar
You really don't want the l36 if going turbo.... L36 is great for topswap though. Moradparts is always having parts on eBay they are one of the biggest suppliers for spare parts for our cars... FYI if u need a low miles engine and trany
Old Aug 22, 2011 | 03:43 PM
bama_z34's Avatar
if i ever do a turbo 3.8 i wanna do a twin turbo setup like the stattama grand prix imagine that setup in a 5th gen monte. mmmmmm
L30555
Jul 21, 2009 03:13 AM
LARZ313
Feb 6, 2009 07:20 PM
ExplosiveSoundz
Aug 1, 2007 09:01 AM
mentiroso
Feb 3, 2007 03:32 PM
76MonteMan
Dec 10, 2006 03:58 PM
