Won't pull over 4000 at 3/4 to full throttle ?
Old Aug 24, 2010 | 07:44 PM
cbenez1's Avatar
Default Won't pull over 4000 at 3/4 to full throttle ?
I have a 2003 LS that just started acting up. The symptoms are Under heavy throttle it stops pulling at 4000 rpm spark knocks like a mother and won't shift into the next gear until you back off the pedal at least half. It has not triggered any idiot lights/codes ? Anyone else had this issue ?
Old Aug 25, 2010 | 11:41 AM
labnjab's Avatar
sounds like a plugged cat to me. Best way to tell is to remove the front 02 sensor and take it for a drive. If performance improves with the o2 out, then your cat is plugged
Old Aug 25, 2010 | 06:53 PM
cbenez1's Avatar
Thanks I'll give that a shot
skylark70
Feb 25, 2014 08:07 PM
garshev
Jun 22, 2011 11:02 AM
MetalDragon
Oct 5, 2008 04:38 PM
mksiler
May 14, 2008 08:08 PM
