white smoke
Old Mar 31, 2005 | 03:40 PM
85MonteSSwhite's Avatar
Default white smoke
Ive noticed some whit smoke coming out of my tail pipe recently. My car is an 85 carbureted ss with a 305. It doesnt smell like anti freeze and my power is up to normal. someone told me im burning too lean. I was wondering if this was true and if so how do i git-er-fixed. Thankyou
Old Mar 31, 2005 | 04:19 PM
Patrick's Avatar
Default RE: white smoke
burning too lean wont make it smoke...is the engine stock? has it ever been apart??
Old Apr 1, 2005 | 07:31 PM
benhillzone3's Avatar
what exacgtly is burnign lean? i never heard of that before
Old Apr 2, 2005 | 02:57 PM
Patrick's Avatar
burning lean means that in your air to fuel mixture, you have too much air, and not enough fuel.
Old Apr 2, 2005 | 03:00 PM
yes it is stock and no i dont think it was ever apart
Old Apr 2, 2005 | 04:49 PM
Patrick's Avatar
as a motor gets to be older, one of the first things to go south is valve guide seals...that allows a tiny bit of oil into the combustion chambers, thus producing a bit of smoke. i would keep an eye on the oil level...if you dont already. also, have you felt any change in performance?
Old Apr 5, 2005 | 12:10 PM
montejass's Avatar
White smoke is generally an indicator that your burning off water somewhere in the combustion process.
I have a few ????? ..
Did this just start happening abruptly?
Is it smoking alot?
There is not much difference between a blue smoke which would be oil burn off and water which would be a little lighter.
Are you losing water from your cooling system?
If it were running too rich your smoke would be more on the black side.
TVW
Old Apr 5, 2005 | 12:51 PM
montejass's Avatar
Additionally, I would pull several if not all of your spark plugs for inspection.
Black/Dry: Running too rich.
Black/Wet: Burning oil
Wet/Rust: Water
TVW
Old Apr 5, 2005 | 09:18 PM
In this forum you learn something everyday even if its not mc related
blackmonte02
Jul 24, 2013 11:20 PM
SoCal01Monte
Jun 25, 2012 10:30 AM
tdunbar5
May 16, 2010 12:46 AM
ltrain925
Dec 22, 2009 11:39 AM
