What carb?
Old Mar 20, 2025 | 10:14 PM
RAMS18's Avatar
Default What carb?
Hey, I’ve got a 1986 MCSS with the 305. I put a comp cams mild cam, performer air gap intake(spreadbore), long tube headers, pertronix coil and ignition module. Still have the stock 200R4 trans. I’m changing the distributor to the vacuum style HEI. Now I need to change the carb. I have the Qjet style intake already so I guess I need a spread bore carb. I ve heard that 600-700 cfm will do, but aren’t the Qjets 750-800 stock. What do I need? Thanks. Steve.
I also removed all the smog stuff.
Old Mar 21, 2025 | 07:21 AM
zucchi's Avatar
The Q-J has air-valves on the secondary bores that control airflow at high RPM so there's no issue with over-carburation.
A really good book you may want to reference is How to Rebuild & Modify Quadrajet Carburetors by Cliff Ruggles:
Amazon Amazon
Since you got an air-gap manifold, you may want to consider a Holley Sniper EFI Quadrajet. There's a YouTube channel called Uncle Tony’s Garage where there's a video about the pros and cons of doing this upgrade:
Old Mar 21, 2025 | 04:57 PM
RAMS18's Avatar
Hey thanks. Another question. If I go with the older style vacuum Hei distributor and use an old style carb. Can I get rid of things like O2 sensors those various sensor trees, knock sensor etc. I do need to keep the ecm for the trans(200R4) correct? What else does the ecm control?
Old Mar 21, 2025 | 05:04 PM
zucchi's Avatar
Yes.
I'm afraid I don't have an answer for you on that. Engine control modules, body control modules, etc., are outside my wheelhouse.
Old Mar 21, 2025 | 06:43 PM
RAMS18's Avatar
Originally Posted by zucchi
Yes.
ok cool, I think the ecm does run the trans but I don’t know what else. Have a good day!
mcss84
Jul 10, 2012 11:14 PM
reye84monte
May 6, 2011 12:19 AM
Decortez
Mar 24, 2011 08:44 AM
Kracktheskye
Mar 2, 2011 03:52 PM
loudNproudSS
Apr 20, 2008 06:53 AM
