Very small transmission metal shavings?
Old May 8, 2013 | 01:03 AM
killerBee's Avatar
Default Very small transmission metal shavings?
Pulled both the cv axle`s and transmission fluid had very small transmission metal shavings in fluid just a few not much. Is this bad or just normal wear? Thought id se what u guys think
Old May 8, 2013 | 06:19 AM
If they are actual shavings then yes, I would say that is bad, something is not working properly.
I know when you do a pan drop, it's normal to see a metallic color mixed in the fluid (this would be a metallic residue or powder from normal wear and tear). But actual shavings (they you might be able to pick up with your fingers, that's bad).
Old May 8, 2013 | 11:35 AM
killerBee's Avatar
I met to say looks like very small metallic in fluid. Not actually shavings.
Cool thats what i thought.
KINGBASS
Jul 1, 2015 04:14 PM
killerBee
Jul 23, 2013 12:26 PM
jwjones
Feb 19, 2012 06:03 PM
nnclyn
Jul 19, 2007 07:34 AM
maclawa
Sep 13, 2006 10:56 AM
