Valve Cover Gaskets Leaking?
Sorry for the less than great picture, but I've got a decent amount of oil pooled where the red highlighted area is below. Could this be pooling from leaking around the valve cover gaskets?
Where else could it come from?
What year vehicle/Type? V-8 or V6?
Its kinda hard to give an answer with no details... Different vehicles ,motors have there own seperate oil leak issues depending on what it is...
I had the same issue, changed my valve cover gasket, it was split in a spot on the top side, best thing to do is pop it off & see if it looks like oil is seeping past it, if so itll prob fix it if not than its prob the LIM gasket
remove the pushrods to do the LIM gasket!...
Once you do that It will become more apparent... In answer to your question...
I've spent quite a bit of time reading up on some good write ups for valve cover gasket replacement and LIM gasket replacement. I know the LIM is a bit more involved, but if I'm already in there for valve cover gaskets, should I just spend the extra 3/4 hours and do the LIM gasket too? I've got 115k miles and I lose about a quart of oil every 4000 miles, although I don't see coolant in my oil and vice versa.
Furder2010
Apr 29, 2013 02:23 PM
MonteNoob
Oct 9, 2010 11:55 PM
prez
Dec 17, 2009 09:21 AM
