Valve Cover Breather?
RE: Valve Cover Breather?
Here's what The W Store has to say about it under TECH...
When do I need a valve cover breather?
You need a valve cover breather when the stock PCV system is blocked on your vehicle. In most cases this occurs when an intercooler is installed that does not have the two PCV holes drilled into it. Installing this on a car that has a functioning PCV system will introduce a vacuum leak and is not recommended.
Yeah, here it is.... it's actually The W Body Store, not The W Store... Sorry about that
http://www.wbodystore.com/
LOL... Go Slowwwwww...
But, just in case you haven't seen these yet, here's a few more to get you in trouble..
http://www.pfyc.com/
http://www.zzperformance.com/
http://www.slponline.com/
http://www.gmpartsdirect.com/
