Upper/Lower intake manifold job...
So wait, you're telling me to get the plastic "help!" ones but the aluminum ones are better? Everything on the autozone website says to stay away from the plastic ones, as the o-rings are not high-temp ones. Is it possible to just get those and add the high-temp o-rings? Has anyone ever done that here?
If someone has a part number for the aluminum ones, that would be awesome. I'd rather not have to do this job once a month (as some have experienced from what I read with the plastic ones).
-Pete
-Pete
FYI - Some (including myself) have had issues with the plastic Dorman elbows popping out. Not sure if the Dorman aluminum ones are better (supposedly the issue was incorrect O-Rings). My current elbows are $30 GM Dealer Elbows.
Also, I'd be stunned if none of your local parts stores had those elbows on the "Dorman HELP!" racks.... That's where you normally find them.
As stated earlier, get the aluminum LIM gaskets from FelPro. Best shopping place for the parts is RockAuto IMO.
And you've seen a lot more then one or two cars working as a mechanic! It's sad the Dorman elbows are about $5 from any parts store around me, yet the GM dealer ones are $30. That is a huge mark up on a product that probably costs the same for GM to make as Dorman. Also, I looked at the costing of the Dorman vs GM, they are slightly different (proving they are not both made from the same factory and put into different packages).
When i redid my gaskets in december i used dormans Aluminum elbows. So far a month and half down the road and i havent had any problems yet "Knock On Wood" But the car runs nice after replacing the gaskets from felpro. I also recommend to do the valve cover gaskets while everything is out. Only takes about 15 Minutes and is really easy! Took me 2 days to do the Gaskets but i took my time cleaning everything thouroughly and making sure everything went back together properly
I just ordered the aluminum ones from AdvanceAutoParts. $15 bucks. As a physics major, I can honestly say that aluminum "should" hold up better than the plastic ones (as far as tensile strength, ability to withstand heat, etc). Giving them a shot. I just hope I can pull this all off within a day inside a garage.
Thanks again for all your help, guys.
-Pete
-Pete
The nylon ones are usually good for 80,000-120,000 miles. SO it will be a while until you see issues again
Wilco
14
Jan 5, 2011 11:16 AM
tjmaples
Dec 15, 2010 09:44 AM
raikel.conerly
Aug 24, 2009 06:52 PM
