Type of transmission Fluid??
![Embarrassment](https://montecarloforum.com/forum/images/smilies/redface.gif)
its much cheaper to go green
![Wink](https://montecarloforum.com/forum/images/smilies/wink.gif)
oh and btw, i bought a new transmission filter which came with a new rubber gasket, seems all cheap and whatnot. should i buy the rubber and steel one just in case??
when i did mine i did it twice because you cant really get the fluid out of the torqu converter unless you do it on good intervals any way. i used dexVI in mine my manuale called for the dexIV i put in the dexVI. after i did it i noticed a better mpg i noticed most dont do it any way and end up with trans problems down the road
I guess this is the best thread to ask,
What, if any additives would you guys recommend for the tranny.
Would Lucas transmission fix be a good "just in case" preventative?
I also just bought some Valvoline Dexron VI synthetic tranny fluid i'll be swapping.
monte is in the garage disabled ![Thumbsdown](https://montecarloforum.com/forum/images/smilies/thumbsdown.gif)
had to order the transmission gasket from autozone so i still havent finished it up![Embarrassment](https://montecarloforum.com/forum/images/smilies/redface.gif)
i got 8 bottles of dexron VI, i was also wondering about adding any additives
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
Don't use ANY additives. Just using Dex 6 is enough.
It's engineered to run cooler and not break down as much when it gets warm. Which is the number 1 killer.
Just try to keep regular flushing intervals now
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
So I got the car up and running last night, I must say it shifts a whole lot better!
Definitely needed some fresh trans oil
Also switched to green coolant and it's been runnin like this all day!!
![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
![](http://i922.photobucket.com/albums/ad68/panchin1992/MCF/bb1fc874.jpg)
