Turbo set up.
Old Sep 14, 2012 | 09:57 AM
turbo monte's Avatar
You don't buy headers with a turbo set up. The turbo replaces the crossover and downpipe and caps off your rear manifold. The only thing that is still stock is the front manifold which is why you should use a Powerlog
You can't safely adjust your shift points past 5900 RPMs without doing the valve springs, however you can throw a turbo on a stock engine. These blocks are really strong, they can hold up to power.
cartuning is making turbo headers designed for there kit now. i am planning on getting a set
Old Sep 14, 2012 | 10:21 AM
I'm curious to know the gains of their headers vs a powerlog setup
Old Sep 14, 2012 | 10:27 AM
i do not know the gains but i know the front is suppose to me like the powerlog just way bigger and the primaries are at an angle instead of straight to help flow. the back is now a header as well and i dont know all the info but im under the assumption that the wastegate sits right on the header now with a "v-band" clamp instead of having the perch....
Old Sep 14, 2012 | 10:31 AM
My whole point is just that the rear manifold isn't that restrictive to begin with, and the powerlog was a great idea on the front.
I know how they are going to funnel it, just wondering if that funneling really does make a huge difference.
Not having a perch is nice though
Old Sep 14, 2012 | 10:36 AM
yea im not to sure, i know on the rear manifold #6 primary caused issues but was easily fixed and other than that the rear manifold was not to restrictive. only other thing you need to consider that im assuming cartuning did is under high hp turbo builds you can crack the plog very easily (people have cracked them on somewhat mild sc builds) so im hoping cartuning solved the issue of them cracking.
Old Sep 14, 2012 | 10:37 AM
I know the cracking was poor welding on the earlier models too. The newer models (i think since revision 3?) haven't had cracking.
Old Sep 14, 2012 | 04:23 PM
Mr Grizzly Mint's Avatar
There header setup is 600 bucks stainless steel. There kit is extreamly cheap considering it comes with a $1000 catback, 42 injectors, t stat, plugs, and full stainless piping. I would get them ceramic coated tho.
Old Sep 14, 2012 | 10:41 PM
01 Monte SS's Avatar
Originally Posted by Mr Grizzly Mint
plus it comes with a fully custom exhaust (downpipe to tips) your choice of brand(SLP, dynomax, or Borla) all you need is a powerlog. The kit litterally comes with everything.
I'm very curious as to where you got this information from? I emailed them about the kit various times and have checked out the site quite a few times as well. I have yet to see somewhere that says they include the catback of your choice? How could they offer the SLP catback anyways, it was discontinued last year (Dec. '11) to my knowledge. Very few vendors that actually have any left.
Are we talking about the same cartuning kit? ===> http://cartuning.ca/special/
Am I missing something? I'm just not seeing a full catback of the buyer's choice anywhere on the site?
42 Lb Injectors
Tuned PCM (plus a core charge if you have a 2004+)
K&N Air Filter
PCV Solution
Autolite 103 Spark Plugs
Full Stainless Steel Turbo Piping (Crossover, Downpipe, Charge Pipes, etc)
Turbonetics Turbo (Full T4)
Turbonetics Evolution Wastegate
50mm Blow Off Valve
Upgraded MAF Sensor
Stainless Oil Lines & Fittings
Full Size 3.5" Thick Intercooler
Thermostat
Gaskets
Hardware Grade 8+
I'm sorry but there's just no way they could offer a full stainless catback/turbo system/and intercooled for that price. A $600-1000 catback for free basically? I really doubt that, especially since it's not listed anywhere on their site that I have found.
Old Sep 14, 2012 | 10:50 PM
misread bullets. my bad. bolts to it lol I need to read closer
  • Precision PT61 Turbo
  • Turbonetics Evolution wastegate
  • Cartuning Blow-off valve
  • Custom-made stainless steel exhaust crossover assembly - mates perfectly to STOCK exhaust manifolds
  • Custom-made mandrel bent TIG-welded 2.5" stainless steel downpipe with u-bend removal
  • High flow catalytic Converter - outlet bolts DIRECTLY to the STOCK exhaust system, Borla Exhaust, DynoMax Exhaust, or SLP Exhaust Systems
  • Cartuning cast aluminum charge pipe (non-intercooled versions)
  • Brand new flow-matched Lucas/Delphi 42.5 lb/hr fuel injectors
  • Custom Reprogrammed PCM adjusts for fuel/timing/shifting/etc
  • Stainless AN oil lines, oil “T”, custom adaptor for oil return
  • 4-ply black silicone connectors
  • Silicone vacuum hose (for connection to wastegate, BOV)
  • Valve cover breather
  • High-flow K&N air filter
  • Stainless T-bolt band clamps
  • All required bolts, nuts, and washers (grade 8 hardware)
  • O2 sensor plug
  • All gaskets for mating surfaces
  • Anti-seize and thread locker mini-paks
  • PCV modification hardware and specialized tools
  • 180 deg. Thermostat
  • 2 range colder spark plugs
  • Full instruction set on CD-ROM
This is the base kit. Another race version too.
  • 42 Lb Injectors
  • Tuned PCM (plus a core charge if you have a 2004+)
  • K&N Air Filter
  • PCV Solution
  • Autolite 103 Spark Plugs
  • Full Stainless Steel Turbo Piping (Crossover, Downpipe, Charge Pipes, etc)
  • Turbonetics Turbo (Full T4)
  • Turbonetics Evolution Wastegate
  • 50mm Blow Off Valve
  • Upgraded MAF Sensor
  • Stainless Oil Lines & Fittings
  • Full Size 3.5" Thick Intercooler
  • Thermostat
  • Gaskets
  • Hardware Grade 8+
these race options extra
  • Pre-welded Cut Out RTR: $379.00 including Cut Out.
  • Cartuning’s Alcohol Injection System RTR : $249.00
  • 3" Downpipe RTR : $499.00
  • Stainless Steel Tubular Exhaust Manifold Set RTR : $599.00
  • Ceramic Coating RTR : $249.00
Here is trand info all I could find besides several spots where they talk about trans builds
Congratulations to Jordan B on his 6-speed manual Grand Prix conversion by Cartuning. The Tilton triple disc clutch and upgraded F40 transmission will help deliver his 600+ Cartuning turbocharged horses to the road. Pictures of the conversion coming soon!
All info pasted from the site so my sleep deprivation does not interfere with actual info
Old Sep 14, 2012 | 10:54 PM
  • O2 sensor plug
Oh I see lol. Regardless it's still a good deal for the price IMO.
