turbo question
Old May 28, 2007 | 09:09 PM
03 SS's Avatar
Default turbo question
what the max boost i can runon a 3.8lwithout having to do any internal work......and can i get away without an intercooler or not?? any help would be appreciated.....thx
Old May 29, 2007 | 09:02 AM
z34phoenix's Avatar
Default RE: turbo question
personally i wouldnt run above 7psi without an intercooler, but there are turbo kits avalible for the 3800 that are in the 9-10 psi range without intercoolers. but at these levels you deff need some good tuning or you will have some major issues.
Old May 30, 2007 | 11:02 PM
04 Intimidator's Avatar
Depends on the car. Some will only go to about 5 lbs of boost and others will goto 8-10. If you run higher octane fuel like 93 or higher you can get away with higher boost. Some of the problem though is with the head gaskets. The gasket has a metal band and it may extend into the the cyclinder. When it does it stays hot and causes knock which will contribute to blowing the engine.
The single and only way to find out is once you have the turbo on, start with 3lbs of boost and scan it. Keep increasing by 1 lb of boost until you get a KR reading. Then backoff 1 lb and you should be dialed in.
Old Jun 3, 2007 | 11:50 AM
03 SS's Avatar
k sweet thanks
vikesfan
Jan 29, 2014 12:23 PM
04SuperchargeR
Jun 11, 2013 06:39 PM
taz7nads
Jul 19, 2012 12:28 PM
bama_z34
Nov 29, 2010 10:00 PM
embharris
Jul 16, 2007 03:36 PM
