6th Gen ('00-'05): Tuned PCM which spark plug?
Old May 19, 2018 | 08:57 PM
michelob's Avatar
Default Tuned PCM which spark plug?
What plug should I put in with a tuned PCM, CAI, resonator delete and aftermarket cat? I think I had NGK's in it before the tuned PCM and it was running great but one of them fouled out and I'm replacing them now and I need wires. Should I stick with the NGK's and what should the gap be?
Old May 19, 2018 | 10:07 PM
Stock plugs, stock gap IMO. That's not really enough mods to change the heat range of plug needed.
Old May 20, 2018 | 08:52 PM
Unless the PCM was tuned for different plugs/gaps, then go for stock.
AC Delco or NGK is your best bet.
