tune up...wires and plugs?
Old Oct 10, 2009 | 03:57 PM
KINGSS's Avatar
Exclamation tune up...wires and plugs?
hey all. my 03 ss has been starting up rough and i think that means its time for a tune up.it has 86,000 miles.just wanted to know what are the best plugs and wires to use.thanks!
Old Oct 10, 2009 | 04:31 PM
skylark65's Avatar
i heard those E3 plugs were pretty good...
http://www.supertruckusa.com/products/55114_108.htm
( yha i know they list em for furd trucks, but that sight has some good info about the product)
keep in mind there is nothing wrong with some plain ol' autolite plugs, it all depends on the size of your budget.
if your doing a tune up, MAKE SURE to get a new air filter and PCV valve, and if you have over 100,000 miles on your car you should probibly do a fuel filter, too.
Old Oct 10, 2009 | 07:17 PM
KINGSS's Avatar
Thanks a bunch will look in 2 it
Old Oct 10, 2009 | 11:18 PM
zipper's Avatar
I would actually go with the NGK TR55's. The E3's are $6.49 each. The TR55's are $14 for six, and they are nice plugs. Check them out here: http://www.zzperformance.com/grand_p...=240&catid=109
They also have wires and fuel filters, etc that you can buy from them.
Old Oct 11, 2009 | 08:07 AM
IMO, I would just get OEM platinum plugs and OEM or equivalent wires. Then you should be good for almost another 100k.
Old Oct 11, 2009 | 10:01 AM
Frosty LS1's Avatar
From what I've learned the L36 engine in stock, or near stock form doesn't benefit from getting "high perforamance" or more expensive wires/plugs. The L36 in that year comes with platinum plugs, guaranteed for 80,000-100,000 miles, and the wires will yield the same results whether they're OEM or MSD or JPG or whatever. Save your money, get OEM replacements and you'll be pleased.
Old Oct 11, 2009 | 02:14 PM
MAMONTE's Avatar
I would stick with genuine OEM AC Delco plugs and wires!
wht02monte
Feb 16, 2010 01:55 PM
wildnorth29
Aug 6, 2009 04:06 PM
White05LT
Feb 14, 2009 08:43 PM
canada3800
Jul 2, 2008 08:28 PM
ChevyMan2008
Mar 15, 2008 05:39 AM
