Triple Alternator setup
#31
As has been asked, but I believe not answered, if you have a moment, what are you doing with THREE alternators & NINE batteries in a Monte Carlo? Let alone ANY basic "coupe"? "Four-door" ... Anything ... Even a Monte on "pumps & dumps" does not need that much ridiculousness. No, really ...
#33
The power is for my car audio SPL (Sound Pressure Level) system. I'm installing two 18" subwoofers and the amplifier is capable of 14,800 watts. So I need the batteries to supply the power and alternators to maintain the power for the current draw.
![](http://i197.photobucket.com/albums/aa8/venfayon/00_Monte_Carlo/Alt/BATT_6_9.jpg)
#35
I was begning to belive you where building a hybrd Monte with electric motors
Wow must put out some sound. honestly though with a sound system like that glad your not living on my block.
#38
cant wait to see what it looks like! you going to be at SBN? im doing 6 12s in a wall but ill only be on 5500 watts for now
#39
It won't be sagging. I got springs from springworks.com and had them made for an additional 1,000 lbs plus K&M performance shocks pre assembled. When I put them on, the back end had no spring action, very stiff. Once I put all the batteries in, the car came down some. It's still a little high on the rear end, but I still have to add a 500 lb enclosure so it will lower to the factory height. The spring assembly rides like the factory ride, nice and smooth.
The only competitions I will enter will probably be local DB Drag in East Michigan
#40
Nice ingenuity for the alternator setup. It seems like you're a person who pays attention to details, so what happened to the "scoops"? The passenger side looks lop-sided. You could've made a oval or teardrop shape with an english wheel that would look infinity times better (and less work). I hope this car is competition only.
How's the gas mileage?
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
