To tranny flush or not?
yes i have done the plugs,wires,upper and lower radiator hoses,both heater hoses,PVC,EGR with the air gap of course and Fel-Pro gaskets.I back flushed it and filled it with Prestone all make extended life antifreeze.
Does it have Dexron VI in it now?If not you are saying it's OK to mix the two correct?
No, right now it has Dexron III in it, but YES it is PERFECTLY ok, actually recommended by GM to mix the Dexron VI. GM only recommends Dexron VI now, and stopped licensing the Dexron III products. So anything in the store you see as Dexron III, is NOT licensed or approved by GM.
I haven't replaced the spark plugs yet. The mechanic I go to said they are good until 100,000 miles. I'm not experienced enough to do the tranny work myself. All I've ever done on my car is change my oil and clean my k & n air filter. I talked to the guy today about the flush, he said it would be $109 for my car. I'll be taking it to him Sat....
for anyone that is going to change the fluid or flush the tranny fluid
1. dexron VI is great fluid.
2. there is a gm TSB about the magnets regarding placement and use of 2 in the pan and a different kind of magnet also.
3. flushing is only good if the trans was neglected and burnt the fluid or is contaminated with something else.
4. if the re-usable gasket isn't still on the car, get one they are the best.
5. DO NOT PUT Lucas trans fix or any other fix-it in a bottle in there if you want it to last.
6. there are 3 steel lines inside the pan, use a small hammer and lightly tap them into the respective attaching points tighter than they were, then use plastic zip ties of good quality and strength and tie them together tightly and cut the excess so it doesn't interfere with the filter. where the 3 go into the casing wrap only 2 lines together but do all 3.
the last step is to prevent the tubes from coming loose which will decrease line pressure causing slips, poor lubrication and overheating of solenoids. for anyone who says a 4t65 is a weak transmission they are wrong, they fail because of these tubes getting loose thats about all.
I'll bet everyone is going to do a trans service real soon now after knowing what i just told you all.
Thanks too all for the info.
VERY informative I will be doing the trans service as soon as time will permit.
soon as i figure out how to post a picture i will show you why Rubbin's Racin'
(Got The pictures to download)
Justin
As soon as you or anyone else can post a picture of the tubes in the pan you were talking about would you do that please?(with the zip ties on them) It looks like the only thing I might not be familiar with.
Thanks
Thanks
if this post was originally made before last friday i could have shown you on my own car...damn i just did all mine because i wanted to switch to the dex 6.
i'll see what i can do the next time a 4t65 is in for trans service at the shop.
okay so i found a picture of a 4t65e with the pan off heres what i explained to do i used microsoft paint to illustrate but cannot get it to post if you want to see what i've done email me at jtk030704@hotmail.com and i'll reply the picture to you.
