Top swap idling still bad, vid included
Old Feb 7, 2011 | 07:45 AM
monte07's Avatar
be very carefull when you take it to a dyno shop. because of the iratic idle and all the last thing i want to hear some thing broke when taking it there
Old Feb 7, 2011 | 07:47 AM
monte07's Avatar
what i mean is you got it running and got every thing together and boom having a issue with some thing else i rather have you happy with the progress that you did when all of it get's running right
Old Feb 7, 2011 | 07:46 PM
Enzo354's Avatar
STILL SLOW
Hmm, well wed. Im getting the front 02 replaced, since i cant get to the dang thing haha. We will see what that does, I think I need to do spark and fueling. Ive got a n* now and its idling way better.
Old Feb 7, 2011 | 08:02 PM
Pure2sin's Avatar
Just make sure the throttle does not catch up on that adapter plate. I had to cut mine because otherwise it wouldn't go past 80% TP. You should take a pic and post it on here of the North* plate.
Old Feb 7, 2011 | 08:05 PM
Enzo354's Avatar
STILL SLOW
Its the ZZP adapter plate, and I think its hooked up ok. Isnt the genv a bit longer than the gen3 is, so your linkage was too long?
Old Feb 9, 2011 | 03:48 AM
Pure2sin's Avatar
Not its not because of the Gen V. The plate on the North* I got was a flat piece of metal and I had to cut a V in it to allow the throttle to get to full 100% TP. It was actually a little short for the cable and was keeping my throttle open at idol. I had to slot the plate and move it to get it to work. The plate on the ZZP North* is crap or at least for my car it was. Good way to check is to just start the car with the throttle cable disconnected.
Old Feb 9, 2011 | 05:13 PM
Enzo354's Avatar
STILL SLOW
Well I replaced my front 02 sensor, its better, but I need to replace my cam position sensor now and thermostat and I should be much better off. My TB isnt the issue.
Old Feb 9, 2011 | 08:59 PM
Pure2sin's Avatar
Good stuff! Get that damn thing running!
TMoney
Apr 9, 2014 09:32 AM
Mar 16, 2013 07:11 AM
Sootah
Dec 30, 2010 02:49 AM
matrx10503
Dec 28, 2010 01:52 PM
mjv247
Dec 15, 2008 06:48 PM
