Top Swap Axles??
Old Feb 5, 2015 | 07:46 PM
78mc-bbc's Avatar
Default Top Swap Axles??
So i've been researching doing a top swap on my 02 SS this spring/summer and found alot of info. But there seems to be no clear answers on the axles needing to be swapped or a hybrid of sorts from the NA car to a supercharged car.
So if i already have the 4t65 trans and i do a top swap and i keep the stock trans no hd diff install. Do i need to swap axles? is there something that changes or interferes with the axles on a top swap?
Kinda confused here, and yes i have used the search function, many times...
Old Feb 5, 2015 | 08:09 PM
Top swap doesn't need any axles changed
Old Feb 6, 2015 | 09:57 AM
nitehawkjcb's Avatar
Your current axles will be fine. I think you can keep the same axles even if you switched to an L67's 4t65e-HD transmission, or upgrading yours to have an HD differential.
Old Feb 6, 2015 | 10:41 AM
78mc-bbc's Avatar
ok thanks for all the help
bumpin96monte
Sep 13, 2013 10:57 AM
rwolf15241
Feb 15, 2013 07:59 PM
jasonsmith
Feb 1, 2012 01:39 AM
l0gitech87
Nov 26, 2010 02:17 AM
reevesjoe
Jun 14, 2008 11:01 PM
