3rd Gen ('78-'80): Timing Chain Cover Leak
Old Apr 16, 2012 | 04:35 PM
rmorman's Avatar
Default Timing Chain Cover Leak
Good Day!
Last fall I installed a 1 piece Fel-Pro PermaDry gasket on my oil pan. I am now paying "Stupid Tax." While doing the install I tried to "clean up" the extra RTV Gasket gunk along the bottom of the timing chain cover. I have created a leak at the bottom of my timing chain cover. I figured while I was having to tear this thing apart I'd upgrade to a Proform 141-218 cover and replace the water pump. As I don't want to do this again any time soon, I'm asking for advice. I believe I'll have to drop the front of the oil pan to fix this. Will I be able to reuse the Fel-Pro PermaDry oil pan gasket? I did as the instructions asked and put a dab of RTV in the bearing cap corners when I did the install. Which RTV should I use on the timing chain cover? Water pump gaskets? Ultra Black? Any and all advice is appreciated.
Thanks,
Russ
Dam20735
May 23, 2013 04:09 PM
forklift
Dec 12, 2011 12:10 AM
One Dark SS
May 14, 2009 02:57 PM
frosty5011
Dec 1, 2007 03:47 PM
fedspunisher
Nov 12, 2006 06:52 PM
