Thinking about swapping the head on the 5.3
i have the 5.3L V8 and i was wondering if anyone had suggestions on any good cylinder head sources? i found this one http://www.compperformancegroupstore...;Category_Code= even though theyre for Ls1/Ls6 i read on wikipedia that the LS4 uses the the same cylinder head as the LS6. Just wondering what your guys opinion's are???
yeah the LS$ has the same heads as the LS6 so you will need a head that flows better for it to be worth it ! i am not sure if any other production head is better but there is alot of aftermarket heads avalible try A.F.R they have good heads
edelbrock ,dart the aftermarket is big for the LS series motors
* the heads in the link look to be kick a$$ heads man they should make power !*
6th Gen ('00-'05): Swapping OEM head unit for another OEM unit...???
Habbibie
Jun 27, 2013 01:09 PM
06BlackSS
Mar 27, 2008 03:02 PM
