things needed for top swap - missing anything?
Old Apr 1, 2011 | 10:58 AM
my00monte's Avatar
Default things needed for top swap - missing anything?
Okay so I figured id make a list of everything I need to do the top swap I want to do this summer. The list is below, please let me know if I'm missing anything or if I can get cheaper/better parts. Thanks!
Top swap kit from Morad $599.99
ZZP gasket kit from ZZP $299.99
ZZP PCM from ZZP $99.99
Speed daddy headers from eBay $208.88
ZZP 3" aluminized cat back exhaust system from ZZP $379.99
Aeroforce scan guage from ZZP $228.99
Extras:
Modular pulley system from ZZP $99.99
A-pillar gauge mount from PFYC $49.99
Maybe a boost gauge and some other gauge?
Old Apr 1, 2011 | 11:11 AM
You missed one part.
A job to fund this.
Lol jk, I don't think you'll need the cat back right away but it's a good idea
Old Apr 1, 2011 | 11:18 AM
you dont need the catback
Old Apr 1, 2011 | 11:37 AM
jwjones's Avatar
jesus with as much as you'll be spending on parts and labor you could just do the full powertrain swap.
Old Apr 1, 2011 | 12:08 PM
my00monte's Avatar
The guy who sold me the car is a mechanic and he said he'd be glad to help me out. And I work at Subway and over the summer I plan to work A LOT. What should I get for exhaust if the catback isn't needed?
Thanks!
Old Apr 1, 2011 | 12:37 PM
stock cat-back is fine for a while.
Old Apr 1, 2011 | 12:47 PM
Milhouse's Avatar
So what do you stand to gain by doing this nearly 2k modification?
Old Apr 1, 2011 | 01:00 PM
If his tune is down pat he should be able to increase his HP from 200crank to almost 280 crank depending on his mods of choice and ability to run a specific pulley knock free.
I still think turbo should be your route of choice...
Old Apr 1, 2011 | 01:51 PM
zipper's Avatar
If I were you, I would try getting your gauges used over on clubgp. There's always someone selling gauges there and you can get some good deals.
I also highly recommend an oil pressure gauge, and you should at least consider a wideband O2 gauge as well (do NOT get a narrowband).
I agree with Chibi. He should be easily capable of getting 280 crank hp (~225whp) with that setup with potential of going much higher.
Old Apr 1, 2011 | 02:01 PM
Enzo354's Avatar
STILL SLOW
I would say engine swap but then ill get attacked so w/e. Dont forget injector connectors.
