thermostat probmlem.
Old Aug 21, 2010 | 10:17 PM
mikepp1977's Avatar
Default thermostat probmlem.
Hi guy just want to see if anyone can help me on this problem. I have a 2003 monte carlo with a 3.4 and every time I put a new thermostat in it works for about 30 minutes and when I stop and turn the car off it sticks in the closed position any help would be great.
Old Aug 21, 2010 | 11:32 PM
you mean after it cools down/fluid stops flowing? it will close because its not warm? how many tstats have you gone through?
Old Aug 22, 2010 | 08:45 AM
mikepp1977's Avatar
It wil do it after I turn it of to go in the store or at someones house . this will be my third I change today im gonna try to find an 180 thermostat
Old Aug 22, 2010 | 08:01 PM
monte07's Avatar
its normal to do that it means that your cooling system is working. before that is the temp gage is getting to the center of the gage and it will go higher? or is it staying lower?
Old Aug 23, 2010 | 09:52 PM
mikepp1977's Avatar
I have been doing some bleeding of the coolant system it hangs around the middle when im stopped at a light .
Old Sep 7, 2010 | 09:33 AM
Dade Chevy's Avatar
the thermostat is supposed to open and close periodically while the car is being driven. thermostats are usually closed so the car can heat up quickly. and will open once the temp is where its supposed to be. if indeed it remains close your car would overheat while being driven. is this the case? sometimes when my 02 monte carlo is idle (at a red light/stop sign) my temp guage may move up a little bit and once i start back driving again then the temp guage will lower. that is normal. hope my post helped
Old Oct 20, 2010 | 09:38 PM
mikepp1977's Avatar
it was a blown head gasket.
Scooby doo
Mar 23, 2010 09:56 PM
batman
Jun 9, 2006 05:52 PM
OilAnalyst
Aug 7, 2005 10:46 AM
04MonteLS
Jun 6, 2005 11:25 PM
Rick
Oct 5, 2004 10:42 PM
