5th Gen ('95-'99): Thermostat
Ok did the job today and its quite a pain. The big issue is simply accesibility to the theremostat and bolts. If you can manage to get your fingers in there to do the work then you'll be good to go. Took me and my dad a good part of the day but the coolant was drained the thermostat was changed. Fresh Prestone full strength coolant was added with water. I bled and bled and bled the car so hopefully all the air is out of the system.
Temperature guage no longer hovers at the bottom, but now sits a little below half. I'd be interested to get an OBD device on it to see what the coolant temp actually is. But otherwise it seems job well done.
Scooby doo
Mar 23, 2010 09:56 PM
