Temp Sensor and Temp Sender. Whats the difference?
Old Nov 25, 2007 | 12:55 AM
smolek37k's Avatar
Default Temp Sensor and Temp Sender. Whats the difference?
Hello,
I went online today in www.rockauto.com and was seraching for the temp sensor in order for my radiator fan to work, I noticed that on their website they have Temp Sender and Temp Sensor and they look like to different items. My question is what is the job of each sensor and also which do I need to replace. Also I would like to know the location of each sensor in order to get an idea of where to look. Please help as I am getting frustrated with this. I also would like to know where are the grounds on the fan wiring in order for me to check it out. I already replaced the relays and still no luck. If I gound the fan it works so somehow the signal is not being transmitted to the fan to kick on. any advice will help.
thanks.
Old Nov 27, 2007 | 07:39 PM
Chucks88SS's Avatar
Default RE: Temp Sensor and Temp Sender. Whats the difference?
The sender i think sends the temp to a gauge, whereas the sensor would tell the ECM to turn on fans.
Old Dec 1, 2007 | 07:08 PM
04 Intimidator's Avatar
Where did you find them? I played with the site for about 5 min but couldn't find those items. What is the path you took to find them?
jimmy2blazer
Apr 7, 2024 02:58 PM
Video
Jul 15, 2013 09:57 AM
farmerjg
Feb 7, 2013 10:05 PM
monte07
Mar 1, 2010 12:21 PM
turner_dtp
Jan 1, 2007 08:48 PM
