superchargin a 3400
Old Aug 28, 2007 | 11:59 PM
h4nsel's Avatar
Default superchargin a 3400
Hey all,
I own a 2003 monte LS I have dual flowmasters, u-bend delete, new coil packs & spark plugs. I tried getting a mass airflow sensor installed but the engine ran way too lean. I'm looking into supercharging my car. Does anybody have any experience or knowledge of supercharging the 3400? Websites, links, experiences...thanks!
Mark
Old Aug 29, 2007 | 02:26 AM
ExplosiveSoundz's Avatar
Default RE: superchargin a 3400
See related post:
https://montecarloforum.com/m_42773/tm.htm
Old Aug 29, 2007 | 10:47 AM
Oh, and as far as lean mixtures on fuel, you would want to buy a PCM programmer that changes your air/fuel ratio at different RPM's.
Something such as the DHP PowrTuner would suffice.
Old Sep 16, 2007 | 12:58 AM
z34phoenix's Avatar
i know of one who did it but they burned up their motor cause it wasnt tuned correctly from the shop who did it. get a tuner and go at it slowly and safely
Old Sep 16, 2007 | 05:42 PM
vita's Avatar
http://www.jeepnuts.com/12sGASE/turbo.htm
Custom Turbo Setup
there ya go... a very helpful link I found
Old Sep 17, 2007 | 09:34 AM
04 Intimidator's Avatar
Get ready to upgrade that transmission as well. Those transmissions are kinda on the weak side in the grand scheme of things and when you throw boost at them it gets worse.
Look at upgrading to HD parts.
Old Sep 23, 2007 | 06:37 AM
I honestly think, after posting what I did, that the turbo setup would be more what you are looking for. Not to mention the fact that you can control the BOOST from that turbo. Unfortunately, with a blower, you are kind of stuck with whatever it puts out at certain RPMS. No matter how you slice it, you are looking at a very expensive upgrade, and unless you are totally serious about that, you might be better to dump your money into a small Nitrous system. lol
-Keegan
Ron A
Jan 29, 2012 10:28 AM
Mikhal
14
Dec 14, 2006 01:32 AM
mista tae
Nov 29, 2006 12:41 PM
mista tae
Sep 20, 2006 01:24 AM
dickie34
Jun 24, 2006 05:34 PM
