Supercharger for the 3900 V6?
Old Dec 28, 2008 | 10:53 PM
hardimans 06 Monte's Avatar
Default Supercharger for the 3900 V6?
Do they make a supercharger for the the 3.9 l (3900) V6 I have an 06 Monte Carlo and I really want to superchargeit!!
Old Dec 29, 2008 | 01:00 AM
Default RE: Supercharger for the 3900 V6?
Are you new to the internet/message forums?
There is no need to post multiple threads on the same topic. I see you have 3 posts, and they're all the same thing starting the same thread in various sections.
You only need to post it once, in the most relevant section.
The easiest way to supercharge a 3900 will be to build your own CSC setup- it would be far easier than trying to build all the custom parts for a positive displacement blower.
Old Dec 29, 2008 | 11:15 AM
88ss408's Avatar
you should look in to a rotrex supercharger or a vortech and you will wave to custom everything but it would be well worth it in the end !
but could get very pricey if you cant do the work your self tho
Old Dec 29, 2008 | 03:28 PM
2 quick4u's Avatar
They only have a Turbo charger for the 3.9 and then you have to pipe it yourself... 6 grand. if it was a 3.8 no problem to get it done. The3.9 have little to go with...
Have a great day....
Old Dec 29, 2008 | 03:30 PM
2 quick4u's Avatar
ORIGINAL: 88ss408 what is the bore and stroke of your motor???
Old Dec 29, 2008 | 08:54 PM
88ss408's Avatar
4.165 x3.750
Old Dec 30, 2008 | 01:39 AM
2 quick4u's Avatar
ORIGINAL: 88ss408 That is doing some serious work to produce that much HP and Tq to that engine... Cam, heads, rods and pistins . Not a overnight job for sure.. I like building the older V8's up. They can make some serious HP from little work.. I could talk all day on them. good luck on it and keep doing it to it...
4.165 x3.750
Old Jan 15, 2009 | 09:48 PM
3900Hero's Avatar
ORIGINAL: 2 quick4u
Umm... did I miss out on the turbo for the 3.9 thread? I'd be all over that, wouldn't care about the ducting as long as the VCM tune is taken care of or at least mentioned... Chances are I probably did miss it...
Old Jan 16, 2009 | 12:40 AM
2 quick4u's Avatar
ORIGINAL: 3900Hero
ORIGINAL: 2 quick4u
This is the site to go to and e-mail them has what you want..http://www.ststurbo.com/home
They make them for the 3.9 Malibu SS
Old Jan 16, 2009 | 05:43 PM
3900Hero's Avatar
Well, is it just the universal kit? I didn't see one listed and I would think it a bit odd that they wouldn't list all of their products....
hardimans 06 Monte
Dec 30, 2008 06:36 PM
hardimans 06 Monte
Dec 28, 2008 11:29 PM
06LT3
Sep 18, 2007 11:18 AM
BeachBumMike
May 23, 2007 06:19 AM
FlynhghR
May 3, 2007 01:56 PM
