Supercharger on a 350 in a 85 Monte ss
Old Nov 16, 2010 | 01:41 PM
85307SS's Avatar
Default Supercharger on a 350 in a 85 Monte ss
I have an 85 monte carlo ss that i converted into a 5 speed and want to supercharge the motor with a 177 Weiand but was wondering if it would fit under a 4 inch cowl?
Old Nov 16, 2010 | 03:01 PM
monte07's Avatar
depends on the size of the supercharger size of the carb and air cleaner. but on the air cleaner you can get a thiner air cleaner. but when getting a super charger ask for the dementions as in the hight of it and go from there.
Old Nov 17, 2010 | 01:55 PM
85307SS's Avatar
Ya i didn't know if anyone has done it because i had seen one online and could not contact anyone about it.
Old Nov 17, 2010 | 05:13 PM
monte07's Avatar
it should work but you will probably need to do some hood work so every thing will work i just wanted to guve you some heads up before setting every thing in stone
Old Nov 17, 2010 | 06:57 PM
sideways's Avatar
Not sure about a 177 but the 142 will fit with a drop base air filter. Which 5 speed are you running? if its a t5 I wouldn't plan on it lasting to long.
Old Nov 18, 2010 | 07:28 AM
85307SS's Avatar
Ya its a T5 but i have a 94 camaro with a T56 and think im gonna invest in one of those after i blow this one.
The Beep
Apr 12, 2008 01:54 AM
Fiky206
18
Sep 30, 2007 08:11 PM
windycitystyle
Mar 15, 2007 11:19 PM
chevyguy20
Mar 12, 2006 11:33 PM
