superchared impala motor!
Old May 4, 2008 | 12:08 PM
hotrodss24's Avatar
Default superchared impala motor!
im not sure if isearched hard enough, but iwant to know if the supercharged 3800 would be a direct swap, useing the engine, tranny, wireharness, instrument cluster, into my N/A monte with a 3800? what else will i need to swap from the impala SS.
Old May 4, 2008 | 07:39 PM
couch's Avatar
Default RE: superchared impala motor!
pcm (unless your going to tune your current one)
Old May 5, 2008 | 01:05 AM
ORIGINAL: hotrodss24
You will also need the passenger side axle.
I would also look into doing an L67 'top swap' basically only changing out the heads on up and adding a blower to your current engine. Costs are much cheaper too- like $500-1000.
The advantage to doing that- is you keep your higher 3.29 gear ratio (you go down to 2.93 if you swap in the 4t65hd- so you'd be slower in the 1/4). Plus, you keep your higher compression which makes more power on the M90 anyways.
Just another option to throw out there...
ttmillus2
Jul 5, 2011 10:28 AM
BeachBumMike
Jan 1, 2007 04:04 PM
White05LT
Dec 18, 2006 07:57 PM
04MonteLS
Aug 23, 2005 11:48 AM
