Strange Leak, '98 MC 3.1
Old Jul 13, 2010 | 12:38 PM
MarkIV396's Avatar
Default Strange Leak, '98 MC 3.1
I have a '98 MC w/ 3.1 V6. We have been running A/C alot lately & it's normal to see a large puddle of water under the passenger side of the car. Lately I have noticed this water not evaporating off the drive like normal. Cleaned the evaporator drain tube & that seemed ok. Check Trans fluid & seem to be at correct level alway - Engine oil as well.
The water on drive has an oily feel to it & no apparent odor. It will evaporate over a 3-4 hour period -which makes me think "Dexcool" or anti freeze.
I've checked coolant level & it's normal. This leaking stuff seems to coagulate on drive - under where the crank is. Lifted hood several times right after driving to see if there is any vapor or leakage. What drops on drive is cool to the touch.
The engine does leak oil at front seal slightly - & I wonder if water from A/C and running some of oil off as well.
Any Ideas .... ??
Thanks,
Mark.
Old Jul 13, 2010 | 12:56 PM
Budsjlm's Avatar
i had noticed on my 00mystique i know compleatly diff type car but that the A/C lines actualy would get condensation on them it may be that going down your block or somthing and taking dirt/oil residue with it
Old Jul 13, 2010 | 01:46 PM
nitehawkjcb's Avatar
Check the underside of your hood. If it's wet above the serpentine belt, then you may have a bad water pump.
Old Jul 13, 2010 | 02:32 PM
MarkIV396's Avatar
Default Leak...
That's just it - there's nothing sprayed on the inside of hood or engine compartment. It's real clean! ???
Old Jul 20, 2010 | 02:04 PM
MarkIV396's Avatar
Replaced Thermostat, Topped off Dexcool to cold level, bled out air with screws.
Noticed w/o air on I never get this leak. When Air is run then it takes a while for it to leak on the drive. Placed a white towel under car expecting "Orange Dexcool" to be found after running a while w/air on. Noting Orange leaked on it - just a merky looking
water w/no odor.
I'm stumped!
Old Jul 20, 2010 | 02:10 PM
MAMONTE's Avatar
Sounds to me like its the water from the A/C running, and its just picking up some crap on its way down...
Old Jul 20, 2010 | 02:16 PM
GrandPaDave's Avatar
Sometimes my A/C condensation has an oily feel to me. It is probably a tiny freon leak of some sort. Have you checked your freon pressures?
Old Jul 20, 2010 | 03:47 PM
MarkIV396's Avatar
I have thought maybe water coming from A/C drain tube could be running down & picking up stuff on the way to the payment. It's not Dexcool!
& No I haven't checked Freon pressure as A/C blows really cool! Good Idea though!
Will have to check that out.
I hope its not a Head gasket leak. There is no vapor or leakage on motor. Very Clean.
Dexcool & Oil looks to be good & not mixing...
Old Jul 20, 2010 | 03:50 PM
Once again, I am old school. I just rub my finger on the puddle, taste the leakage, compare the taste to what I know, and bingo, problem solved.
Old Jul 20, 2010 | 05:18 PM
1984SuperSport's Avatar
mhmmm now thats how u do it! lol
