95 MC Z34
Old Feb 12, 2007 | 02:01 PM
smolek37k's Avatar
Default 95 MC Z34
Hello,
I wanted to know, on 95 MC's with the 3.4 DOHC, does the temp sending unit control the fans or is their an fan switch like most cars, I have searched for a fan switch and get nothing but a temp sending unit that is screwed to the bottom of the plenum next to the thermostat.
Any info will help,
thanks
Old Feb 12, 2007 | 05:32 PM
z34phoenix's Avatar
Default RE: 95 MC Z34
the fans are controled by the computer. it uses the temp sending unit (coolent temp sensor aka ECT engine coolet temp sensor) to activate the fans at pre set temps.
Old Feb 12, 2007 | 06:05 PM
smolek37k's Avatar
Thanks for the reply, I have switched out my relays to new ones, as well as checked the fans itself and they work good when grounded, the only thing that I believe will cause this is the temp sending unit, I know that even if you get a reading in the gauge itself it does'nt mean that the temp unit is actually sending the signal to the relays. So I believe that the next thing I have to replace will be the temp sending unit for a new one. I get a reading on the temp guage but no signal to the relays to open up and turn on the fans. any ohter info would be appreciated.
thanks
Old Feb 13, 2007 | 06:48 AM
z34phoenix's Avatar
i would check the wires from the computer to those relays then. cause i doubt the computer would just stop controling the fans. and if the fans, relays, and temp sensor is all good, then i'd guess its a break in the triggering wire for the relays. i dont think we have a seperate temp sending unit. the computer just reads the sensor and trigers the fan relay
jet404
Aug 22, 2005 12:51 AM
96_z34
Jul 26, 2005 03:35 AM
amhoet
Jul 15, 2005 11:55 PM
mah40
Jul 12, 2005 05:37 AM
mah40
Jul 9, 2005 09:13 PM
