Stage Kit
Old May 25, 2011 | 11:06 AM
lade03SS's Avatar
Default Stage Kit
Hey everyone,
I recently acquired a 3800 Stage 1 kit (3.4 pulley, 180* thermostat, CAI, NGK 104 spark plugs) I'm looking at adding this to my 2004 SS. I'm going to get a down-pipe and gauges, before I add the stage kit. Would you recommend a 2.5 or 3 inch down-pipe? Then I want to add gauges for tranny temp, as well a aftermarket boost gauge since ours only goes to 10 PSI. After I get those done would you recommend using a tune from ZZP/3800 or going to a shop and have them tune it for how I want to maximize the potential of the stage kit?
Old May 25, 2011 | 02:32 PM
since you're supercharged a 3 inch downpipe would be your best bet, you should probably then go to a shop to get the tune done for better results
Old May 25, 2011 | 06:33 PM
3" DP.
Also, I'd scrap the gauges for now, and spend that money on some 1.9 modded stock rockers to try and help kill some of the knock you're going to get.
Obviously a custom tune is better- but the price isn't remotely comparable. If you're thinking about having a shop do a custom tune, have you thought about picking up a used DHP PT or HPT and doing it yourself? You can easily buy a DHP PT for the cost of what any shop would charge you for a single tune- it just takes time to read and learn.
However, the big question to me would be how far you plan to keep going. If you're stopping at a basic 3.4", I'd just throw a canned tune in there and be done with it to keep it as affordable as possible.
Old Jun 2, 2011 | 09:14 PM
lade03SS's Avatar
so getting the stage kit put on tomorrow... Wanting to know if i'm going to be running rich or lean b4 i get it tuned Monday
Old Jun 2, 2011 | 11:20 PM
nitehawkjcb's Avatar
Every engine's different. Screw the downpipe, just get headers. And a scan gauge.
Old Jun 3, 2011 | 05:17 PM
I'd imagine about the same- your MAF reads the amount of air coming in, so the increase in airflow will be adjusted for via the fuel trims. Obviously it'll make boost a little earlier, and such- so as far as your AE and such, maybe a little leaner there- but it'll learn the new fuel trims over time. Not that it really matters either way, since you can't adjust it yourself.
x2 on headers, and a scan gauge (or at least someone scanning your car once you get the pulley on) is a good idea too. IMO a DP, CAI, plugs, and tstat won't kill all the KR you'd get from adding a 3.4" pulley (unless you're super lucky and were nearly knock free on the stock pulley)- so if you have a good bit of KR- I'd wait on getting the tune (if you're having it actually custom tuned by a person) until you get a few more hard part mods (like a PLOG to go with the DP- or headers in place of both, or maybe some 1.9 rockers)- so the tuner isn't having to pull timing and flood the thing with fuel to get the knock gone.
I've helped people try and tune setups that had massive KR on a 3.4 (due to minimal actual mods on cars that were already knock monsters with the stock pulley), and once we got fueling and such dialed in- we were still having to pull timing, and add lots of WOT fueling to keep KR in check- ended up making the car barely faster than stock since the AF was so rich and timing was so low (these cars seem to have a sweet area for timing- too high, and you stop gaining any power, and too low and power starts dropping off fast).
Ace25
Nov 16, 2012 10:30 PM
superrod29
Mar 23, 2010 01:38 PM
ar3em11
Jul 21, 2008 08:57 AM
04MonteLS
Jul 24, 2005 06:51 PM
ag3nt0r4ng3
Jul 18, 2005 06:45 PM
