son new 2000ss trans HEADACH!!!
Old Aug 22, 2009 | 07:52 AM
Ronnie Shephard's Avatar
Default son new 2000ss trans HEADACH!!!
I just bought my son a 2000 ss. 125k on the 3800. Did great on the 3, 15-20 minute test drives but after buying it, on the 70 mile drive home, the ckengine litecame on, and trans seemed to be stuck in 2nd or 3rd. I went straight to AZ, pulled codes...all 3 trany. I took it to a transmission shop right then(before i knew about this forum) and he said $1500.00 to rebuild. He said the codes were shift sonlnoids and it had a shaft that was stripped causing my TRaction Control and ABS light, and it needed updates so i had them rebuild it.
Well long story short, i got it back from the shop yesterday and the trans still seems to act up(slip or stick or hard shift on occasion) and thro the check engine lite. He said that was NORMAL on a newly rebuilt trans because it had to re-learn everything...He said to pull over, shut it off, and restart. That seems to work but IS THIS CORRECT or he blowing smoke up my pant leg???
Also if he rebuilt the trans and its still giving me problems, COULD IT BE THE PCM causing that type of trans issue.
Please advise
Old Aug 22, 2009 | 08:04 AM
Thumbs up
..Hi Ronnie, sorry 2 read about the problems that you are having with your son's Monte Carlo. Check back to see what our Expert Tech Member's post when they read your Thread questions....Until then, you may want to check out the below links...Good Luck from `Space : )
PCM Security Relearn Procedure
PCM Security Relearn Procedure for 1998-02 Buick Regal GS and 2000-02 Chevrolet Monte Carlo. In the event that your vehicle fails to start after installing ...
www.3800performance.com/pcm_security_procedure.htm - Cached - Similar
2000 Chevrolet Monte Carlo with Intermittent Sta... - JustAnswer
Chevy question: 2000 Chevrolet Monte Carlo with Intermittent Starting Problem. ... new security code and it will have to sit for some time to relearn the new code or if ... Passlock Module/BCM or the PCM (if necessary - see note above). ...
www.justanswer.com/.../1h8jm-2000-chevrolet-monte-carlo - Cached - Similar
Automotive Car and Truck Repair Question and Answers by GM Experts
Why does my 2000 chevy Monte carlo dies. .... Relearn procedure. Security learn procedure for 2000 olds Alero after ignition replaced. ... 2002 Grand am SES p0300 p0404. EGR ? Catalytic converter ? PCM ? ... ABS making a clicking noise when slowing down. 2000 Chevrolet Cavalier. ...
www.greatautohelp.com/QApage.html - Cached - Similar
GM A T S U
module requires a PCM relearn. Remember: Use this as a general guide! ... Monte Carlo 2000-on. Pontiac: Sunfire 95-on, GrandAm 96-on ...
www.aatecusa.com/.../SMP%20Tech%20Tip%20Spring%202002.pdf - Similar
Free-Auto-Repair-Advice: GM Anti-Theft Systems
May 29, 2009 ... If it is, the module sends a signal to the PCM to enable the engine. ... you have to perform a Powertrain Control Module (PCM) relearn procedure (need a programming scan tool). ... Chevrolet Cavalier 95-on. Impala 2000-on. Malibu 97-on. Monte Carlo 2000-on. Oldsmobile Achieva 96-on. Cutlass 97-on ...
free-auto-repair-advice.blogspot.com/.../gm-anti-theft-systems.html - Cached - Similar
Old Aug 22, 2009 | 08:09 AM
mrl390's Avatar
Your catalytic converter may be clogged up. I have heard of people having problems with their trans acting up when their converter was clogged. Not sure why it does that but with 125000 miles I would say there is a good chance your converter is clogged. Maybe someone who has had the same problem will chime in.
Old Aug 22, 2009 | 12:53 PM
MonteDriver's Avatar
clogged cat will cause a feeling of slippage and hard shifting, it will be like the computer is hunting for the shift point. In reality the computer is, when its increasing fuel/air it checks the o2 sensor and see's high fuel cause the cat is not working properly. it in turn lowers fuel mixture and starves motor, this causes the tranny to not want to shift because it needs more power. this will be most evident in high rpm's or under a load, like climbing hills.
Old Aug 31, 2009 | 08:45 PM
Update..Took it back to trans shop, they replaced the pcs solonoid and a harness and trans is perfect now. BUT now the steering seems messed up.
It was tight and centered, not it pulls slightly to the left and there seems to be some play in steering wheel.
Any thoughts.
dgm
Apr 6, 2014 12:33 PM
dgm
Apr 5, 2014 11:08 PM
deezdrama
Jun 7, 2012 08:01 AM
Ronnie Shephard
Sep 2, 2009 08:44 PM
2000montesspinnin
Nov 18, 2008 11:54 AM
